How To Remove And Install Stair Spindles - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 12:08 PM   #1
Rewards Points: 666
How to remove and install stair spindles
I have attached a picture of wooden spindles that I have in my home. I have never tackled this before. How do I go about removing them? I am wanting to replace them with wrought iron spindles. "Typically" how are those installed(attached)?
kennykenny is offline   Reply With Quote
Old 02-05-2014, 12:19 PM   #2
Rewards Points: 13,694
Remove top rail, they can be just sitting in counter bored holes with dowels on the spindles or they may be screwed in with dowel screws.
http://www.bing.com/images/search?q=...electedIndex=0
Old 02-05-2014, 12:21 PM   #3
joed's Avatar
Rewards Points: 12,854
Typically they are doweled at the bottom and tack at the top. There could be spacers that have been nail in between the hold them.
Removal without damage could mean removing the hand rail.
Old 02-05-2014, 07:23 PM   #4
Rewards Points: 144
They are typically glued too so this could be a chore.Check for nails or screws at the top first.
mako1 is offline   Reply With Quote
Old 02-05-2014, 07:52 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
Start at the top of the stairs and remove the filet in the bottom side of the hand rail. Most times the spindle can be removed by hitting it at the top, be careful not to knock the lip off the bottom of the rail where the filet was removed. Some people just tack the top of the spindle and not glue if so it will be easy to remove the spindles.
To install the metal spindles you will need to install a continuous filet under the entire rail, then just install the metal spindles.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Remove individual window to install venting tozier9 Windows and Doors 11 02-05-2014 10:40 AM
Vinyl Siding Install: Remove Current Lap Boards? Smahoney6 Building & Construction 22 05-30-2013 04:23 PM
Do I have to remove Baseboards for flooring install worldbfree Flooring 8 01-02-2013 04:42 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 05:46 PM
Installed pocket doors, now how do I remove the wood to install the hardware amdspitfire Carpentry 8 11-21-2008 01:43 PM
