Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-16-2011, 12:03 AM   #16
How to Remove Gainsborough Doorknob?
Thank You so much for the answer about these door locks.
Just moved into a house and was half way to replacing the door lock when I got stuck.
Cheers
Alf
Posidon is offline   Reply With Quote
Old 01-01-2013, 03:36 PM   #17
Thumbs up
Turning the trim plate counterclockwise worked for me. Yay! (I wore a vinyl glove.) Both sides came off the same way.
The knob has been half off for a year. The door rattled. I began making adjustments, but could not completely remove the knob--until today. Put it all back together and the door still rattles, but at least we don't have to open and shut it for guests with a folded up paper towel!
Making out the brand name was difficult but worth it. Other websites insisted I must depress the missing detent!
Thank you!
bugmenot is offline   Reply With Quote
Old 01-18-2013, 06:54 PM   #18
I too had a problem with the Gainsborough and my sister in law has a house full of them. With some non-slip matting and the "counter-clockwise" knowledge it is such an easy job to get to the hidden hardware.
phool09 is offline   Reply With Quote
Old 04-19-2013, 12:53 PM   #19
Thumbs up
I just used the instructions posted here and my problem is solved.
undertoe is offline   Reply With Quote
The Following User Says Thank You to undertoe For This Useful Post:
Maintenance 6 (04-22-2013)
Need to remove toilet temporarily pomelo Plumbing 4 08-22-2009 05:39 PM
Opening up a Bathroom - What can I remove? webgeek Carpentry 7 01-21-2009 12:01 PM
Remove Joist Bridge?? busy1 Building & Construction 9 09-01-2008 10:56 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing 3 07-02-2008 03:10 AM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
