How To Protect The Deck From The Winter - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-03-2013, 04:32 PM   #1
Rewards Points: 119
How to protect the deck from the winter
Hi all,
After weeks of hard work I finally got my two levels deck to real wood stained color.
Pressure washer stripping, sander and three times natural stain.
Now, I am in Canada and winter is coming soon, I wanted to find a way to protect the floor from the snow and ice and I was thinking to cover it with thick transparent plastic nylon, so that I can easily shovel the snow without any contact with the wood floor.
What's your opinion on this?
Alex
Metallo is offline   Reply With Quote
Old 10-03-2013, 06:53 PM   #2
Rewards Points: 13,750
Waste of time and money.
Old 10-04-2013, 05:29 AM   #3
Rewards Points: 119
Well, at least tell me why...
Old 10-04-2013, 06:46 AM   #4
DIY staff
Rewards Points: 7,174
Any covering you put over the wood deck will hold moisture ---this will degrade the wood ----
Old 10-12-2013, 12:08 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
It will trap the moisture against the deck and probably do more harm than good.
Sorry but there is no real easy solution here.
Try brooming the deck when the snow comes down.
Old 10-13-2013, 09:22 AM   #6
Rewards Points: 236
or a leaf blower. if the snow is not wet.
Fix'n it is offline   Reply With Quote
Old 10-13-2013, 09:44 AM   #7
Use a plastic blade snow shovel and I doubt that there would be any damage that can be measured or observed. The wood will rot before you would damage the boards with a snow shovel.
My concerns with covering it are as the others...trapped moisture. This will cause more damage than a snow shovel.
oberkc is offline   Reply With Quote
Old 10-13-2013, 10:35 AM   #8
Rewards Points: 582
just provide a good sealer as most people do to provide a good look and to prolong the life of the wood...ben sr
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
General questions re: platform deck with slanted roof trolle Building & Construction 4 04-15-2013 09:47 AM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
