#1 |
How much wood will be used for a 1,500 Sq. Ft House
A friend and I are trying to figure out how much wood will be needed to build a 1,500 Sq. Ft house.
#2 |
Tileguy
Wouldn't that depend on a lot of things? Such as member spacing, size of interior rooms and walls, roof pitch, garage, etc, etc.
You should get some plans together and take them to a local lumber yard for an estimate. |
#3 |
Residential Designer
3 .62 cubic yards in 5 piles.
Or 5.62 cubic yards in three piles. One of the two. Andy. |
#4 |
Disabled wood vet
Sign me over a blank check (I have friends that can vouch for me).
I'll see to it that the right amount gets ordered. |
| The Following User Says Thank You to titanoman For This Useful Post: | rossfingal (12-23-2011) |
#5 |
"Nail-Bender"
Take the blueprints to a lumber yard -
They'll figure out a framing package. You do have blueprints/plans? Happy Holidays! rossfingal |
#6 |
retired union carpenter
draw out your plans to scale on graph paper, use overlays for interior walls and roof. count The squares and add 20%.
we don't know how you want to build your house!
as always, just my thoughts good luck....coupe/Larry take what helps? ignore the rest. |
#7 |
journeyman carpenter
the amount of lumber that goes into a 1500 sq ft house can vary quite a bit. how many bearing walls are in it and if its cut up a fair amount with parttions or open concept. if its open concept a large amount of money will go into either engineered lumber beams or steel beams
#8 |
How much wood will be used for a 1,500 Sq. Ft House |
#9 |
draw out your plans, figure out the linear footage of walls 2x4? 2x6? triple footage for top and bottom plates. 16" on center takes 75 members to build walls,floors, joists and rafters 24" centers takes 51. plywood covers 32 square feet. for floors and roof. draw to scale to get rafter length including overhang? don't forget ridge pole.
add about 20% for temporary bracing, jack studs and extra nailers where needed and blocking grab your calculator. it should get you in the ballpark.
as always, just my thoughts good luck....coupe/Larry take what helps? ignore the rest. Last edited by coupe; 12-24-2011 at 04:20 PM. Reason: add coment |
#10 |
Stairguy
It's a very open ended question.there could be man different answers. Are you talking only framing, or finish too? Not that that I, or anyone would answer that anyway.
| Display Modes | |
| ICF vs. Wood Framed | JackOfAllTrades | Building & Construction | 31 | 11-01-2011 04:14 PM |
| Repairing wood rot at base of beach house 10" x 10" posts | mikebeahn | Building & Construction | 1 | 10-25-2010 12:57 AM |
| Different paint type for outdoor house wood paneling? | gante | Painting | 10 | 03-23-2009 02:19 PM |
| wood roof frame on old brick house | Stealthfox | Roofing/Siding | 9 | 09-03-2008 08:55 PM |
| Complete AC installation in Old Capitol Hill Row House | jacko10 | HVAC | 0 | 09-18-2007 06:42 PM |
