-   -   How much wood will be used for a 1,500 Sq. Ft House (http://www.diychatroom.com/f14/how-much-wood-will-used-1-500-sq-ft-house-127444/)
Ejt2525 12-22-2011 10:30 PM
A friend and I are trying to figure out how much wood will be needed to build a 1,500 Sq. Ft house.
Bud Cline 12-22-2011 10:39 PM
Wouldn't that depend on a lot of things? Such as member spacing, size of interior rooms and walls, roof pitch, garage, etc, etc.
You should get some plans together and take them to a local lumber yard for an estimate.
AndyGump 12-22-2011 10:44 PM
3 .62 cubic yards in 5 piles.
Or 5.62 cubic yards in three piles.
One of the two.
Andy.
titanoman 12-22-2011 10:55 PM
Sign me over a blank check (I have friends that can vouch for me).
I'll see to it that the right amount gets ordered.
rossfingal 12-23-2011 08:14 AM
Take the blueprints to a lumber yard -
They'll figure out a framing package.
You do have blueprints/plans?
Happy Holidays!
rossfingal
coupe 12-23-2011 03:02 PM
draw out your plans to scale on graph paper, use overlays for interior walls and roof. count The squares and add 20%.
we don't know how you want to build your house!
woodworkbykirk 12-23-2011 03:59 PM
the amount of lumber that goes into a 1500 sq ft house can vary quite a bit. how many bearing walls are in it and if its cut up a fair amount with parttions or open concept. if its open concept a large amount of money will go into either engineered lumber beams or steel beams
Tizzer 12-24-2011 01:15 PM
Whatever amount ya'll come up with, triple that as you haven't a clue.
coupe 12-24-2011 02:27 PM
draw out your plans, figure out the linear footage of walls 2x4? 2x6? triple footage for top and bottom plates. 16" on center takes 75 members to build walls,floors, joists and rafters 24" centers takes 51. plywood covers 32 square feet. for floors and roof. draw to scale to get rafter length including overhang? don't forget ridge pole.
add about 20% for temporary bracing, jack studs and extra nailers where needed and blocking grab your calculator. it should get you in the ballpark.
:thumbsup: meant to say takes 75 members to frame 100'
Millertyme 12-24-2011 04:09 PM
It's a very open ended question.there could be man different answers. Are you talking only framing, or finish too? Not that that I, or anyone would answer that anyway.
