How Much Opening Space Lost To Attic Ladder? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 09:17 AM   #1
Rewards Points: 42
How much opening space lost to attic ladder?
I am considering buying a Werner televator attic ladder to put into a rough opening of 24 by 30.
Does anyone know roughly how much room the ladder takes up when it is down? For instance, would this sized hole end up being about 24 by 24 with the ladder in place?
I am trying to figure out what I'll still be able to get up through the hole.
dweeter is offline   Reply With Quote
Old 12-05-2009, 09:30 AM   #2
With a 24" opening, you only end up with about 22" between the outside frame of the ladder. It gets small real quick.
sausagefingers is offline   Reply With Quote
Old 12-05-2009, 09:31 AM   #3
I think it takes about six inches. It's hard to get anything much larger than a computer up through the opening.
pyper is offline   Reply With Quote
Old 12-05-2009, 10:22 AM   #4
Old School
Willie T's Avatar
A typical attic ladder frame (if 3/4" lumber) works out to these measurements in width.
Willie T
Old 12-05-2009, 10:50 AM   #5
This is an atypical ladder. There is no frame, just the lumber, and the ladder bolts to the lumber -- it attaches to a single "header" piece. I just measured. My opening is 29.5" With the ladder in the down position, there is 21" of clearance from the front of the ladder rail to the edge of the opening.
Old 12-05-2009, 11:00 AM   #6
Looks like something I might get. But does the ladder affect insulation in the attic and the access hatch itself?
Mike in Arkansas is offline   Reply With Quote
Old 12-05-2009, 01:54 PM   #7
I have a 3/4 inch piece of pink foam glued to the attic side of the hatch.
The ladder goes up and then "flops" over. when it's up it's only about a foot tall, and it's hinged a bit higher than the top of the joist, so if you had insulation right there it might compress it a little. Since the ladder only occupies a little area, I have a piece of cardboard that covers the opening from the top side. Doing that makes an air space. I think I might make a better attic side hatch some day.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
attic space rhys99 Roofing/Siding 5 08-21-2009 07:20 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 05:48 PM
