Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-13-2011, 10:39 AM   #1
how much larger should the window frame be than the casing
I ordered some windows and I have the dimensions of the casings.
How much bigger than the casing should I make the frame. I was thinking 1/2" so I'd have 1/4" play on all sides... but seeing as I've never done this before, I thougt I'd ask.
thanks
graysqwrl is offline   Reply With Quote
Old 08-13-2011, 02:22 PM   #2
you can probably go online to the window manufacturer and find the directions for installation. for new installs, i would personally like 3/8 to 1/2 inch on each side.
1910NE is offline   Reply With Quote
Old 08-13-2011, 02:47 PM   #3
remodeling pro
thanks
You would be a little safer with 3/4", unless you are very carefull about level and square, and the straightness of the wood around the window, 1/4" on each side is not much.
troubleseeker is offline   Reply With Quote
Old 08-13-2011, 03:08 PM   #4
Framing Contractor
thanks
The casing mean nothing. You must be talking about the rough opening. All you have to do is ask the place where you bought the windows from and get the rough openings. Every window manufacture gives them to you.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-16-2011, 01:01 AM   #5
Framer
100% agree with you. Some manufactures for a 4' window will have the rough opening be 4' even while some want the opening to be 4' 1/2. ALL depends on what they recommend..
Good luck
joeyr is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
How to fix a broken frame corner of a slide window George II Windows and Doors 1 05-07-2011 03:04 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
Window Casing around Vinyl Windows tcoshea Building & Construction 3 11-28-2007 10:52 PM
