How Much Drywall To Use??? - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-04-2008, 07:44 PM   #31
yeah
Yeah 8 bucks a sheet ain't bad at all I was thrilled with 4.99 for a 4x8 sheet on sale . But it just doesn't make any sense to use them if all you pros are saying use 12' or even 14' Thanks for everyones help
Tdoggy187 is offline   Reply With Quote
Old 03-11-2008, 04:26 PM   #32
CT Builder
it has been 1 week since your last post can we ask of your progress?
have you run into any snags or difficulties?
-Daryl
Daryl is offline   Reply With Quote
Old 03-11-2008, 07:36 PM   #33
Updates...
Have not started the actual dry walling process yet. I am currently in progress of gutting the upstairs. Trying to save some work for the contractor doing the job. Going to also have to put the roof up first this spring. "Which is right around the corner" I have started to rip down the walls in the master bedroom. The Plaster will not come down in whole pieces :-( It is piece by piece. Very annoying. I so far have found a "bee hive" in my master bedroom wall! And a Burnt piece of wood??? Guess there was a fire at one time. Strangely thats the only burnt piece of wood so far???
I see two layers of would inside the "Plaster and Lathe" And it looks to be in pretty good shape! So hopefully I can get some insulation in there and then seal it up with some Drywall.
Atlantic I wish you lived closer :-( I'd have you come to take a look and probably do the work!!! If you wanted of course
Old 03-11-2008, 09:09 PM   #34
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks for the offer.
- Build Well -
Old 03-11-2008, 09:10 PM   #35
-Daryl
Reminder: It's a DIY site....
You're on the wrong time table....
- Build Well -
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
