How Much Drywall To Use??? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 09:40 AM   #1
Question
how much Drywall to use???
Guys this is my first ever project. I measured the room sizes. Now I'm wondering how much drywall I need? I didn't measure the doors or windows. I just measured straight across both ways.
here is what I have:
Master bedroom 13x15 one door, 2 windows
bedroom "extra room" 11x21 one door 1 window
bedroom 13x15 one door 2 windows
open room 15x12 2 windows no doors stairs going downstairs
Windows all look to be the same size. And so do the doors. If you want me to I will measure the windows and doors.
Any ideas???
Tdoggy187 is offline   Reply With Quote
Old 02-26-2008, 09:54 AM   #2
She'sapainter
Multiply your sq ft and devide by 32 don't take out for windows or doors because you will need to allow for brackage.
Any ideas???
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 02-26-2008, 01:55 PM   #3
Rewards Points: 150
don't forget ceilings (if req'd). If ceilings are 8'-9', you might consider 54" wide rock (which would change the "divide by 32" part)
steve1234 is offline   Reply With Quote
Old 02-26-2008, 02:11 PM   #4
What size sheets are you getting? If you're having a company deliver it, ask if they carry 14' sheets. Depending on which way the joists are running, it may cut down on a few butt joints in some of those rooms.
jerryh3 is offline   Reply With Quote
Old 02-26-2008, 03:04 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Any ideas???
This is based on using 12' sheets. I recommend that you use 12' not 14'. They will be easier for you as a newbi to install, especially on the ceilings.
Standard sized windows don't really matter, as the top sheets are hung right over them, and the opening cut out. 4 doors = subtract one sheet.
13x15 Master B.R. : 13.5 sheets
11x21 Extra Room: 16.5 sheets
13x15 Bedroom: 13.5 sheets
15x12 Open Room 13 sheets
Total: 56.5 sheets
4 doorways (subtract at the lower section of sheet = about 36" (per door) x 4 (rooms) = 144" (12'-0") = subtract 1 sheet = 55.5 sheets.
55.5 sheets, rounded off = 56 sheets.
That is based on rough-exact. You might want at least one extra sheet (just in case/fudge factor), and at least one more to account for miss-cuts.
Are there any closets?
If not, here you go:
Actual total: 58 sheets of 12'-0" sheetrock (3/8")
One case of 1-1/4" inch course-thread screws for rough framing (tho, you need to use 1/2" if doing that. If going over old sheetrock, figure using 1-5/8" to 2" screws, possibly 2" for the ceilings?
Figure for corner bead
Paper tape
Joint compound (usually one bucket of ready mix for every 10 sheets)
Hopefully you are getting it delivered. Make sure that they disperse the sheets around the living area for ease of installation and to distribute the weight load on the flooring joists.
Good Luck
- Build Well -
Old 02-26-2008, 03:22 PM   #6
Ok. 14's may be a little much for a beginner to handle. Otherwise, do everything Atlantic wrote. You may want to get one case of glue if you decide to use adhesive(which I highly recommend).
Old 02-26-2008, 04:51 PM   #7
She'sapainter
What ever you do dont forget the sheet rock lift.....We just built on 1700sq feet up to second level rough ...I am finishing the taping getting ready for texture. What a job...good luck
Old 02-26-2008, 06:36 PM   #8
Question
I see
Wow not as easy as I thought. Yeah one room has a closet. The master bedroom. Glad you guys told me about the 12' sheets.
I'm thinking of getting everything at once. I also have a downstairs bathroom I have to do the ceiling on and eventually the kitchen and another bedroom. I have to measure these. Then I'll ask for your guys advice
Atlantic are you counting the ceilings? I have to do all the ceilings in those rooms as well.
I'm not going to do it myself just yet. I will be using someone who is pretty experienced. Should I still use 12'?
Old 02-26-2008, 08:05 PM   #9
I am counting the ceilings.
Are you installing the S/R on rough framing? If so, you need to use 1/2" S/R.
If you are "overlaying walls and ceilings, then 3/8" is good.
Bathroom ceiling: Use XP board.
- Build Well -
Old 02-26-2008, 08:07 PM   #10
Closet: If that needs to be sheetrocked, then you need material for that too.
- Build Well -
Old 02-26-2008, 08:35 PM   #11
Question
Gutting it
I plan on just gutting everything. Probably the whole upstairs. So it should be just wood framing left. Then I plan to put up some insulation and drywall. Sound about right?
I just measured the Kitchen, bathroom, and downstairs bedroom. This is what I got. I'm doing ceilings for these three. No walls.
Kitchen 22x18 The 18 is at its biggest point. I'm assuming this will leave me with extra sheets.
Bathroom is 8x11
I plan to do the upstairs first. Then work on the Kitchen, bathroom, and bedroom downstairs eventually. They are just ceilings.
Bedroom 11x11
Old 03-04-2008, 11:52 AM   #12
Atlantic can you Help please
I'm going to buy all the drywall now. since i can get it at 4.99 a sheet. I know what i need thanks to you "Atlantic for the other rooms but I'm not sure what I'm going to need for these three rooms that I didn't list. Can you please give me an idea. Thanks
Bathroom is 11x8
Bedroom 11x11
Old 03-04-2008, 11:55 AM   #13
Be happy to help, when I have the time. Busy right now, I have 3 detailed estimates I HAVE to get out the door today....
- Build Well -
Old 03-04-2008, 03:36 PM   #14
Thumbs up
ok no rush
Take your time and Thank You very much
Old 03-04-2008, 04:19 PM   #15
4.99 per sheet: What lengths?
I am confused by what you mean.."the biggest point"?
12' sheets: 18.5 = 19 sheets (rounded off)
Bathroom is 11x8
12' sheets: 4
8' foot sheets: 7
OR (dependant on the direction of the strapping/joists):
12' sheets: 6
8' sheets: 4
Bedroom 11x11
12' sheets: 11
Are these all 8 foot ceilings?
- Build Well -
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
