How Much Do New Dormers Cost? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 03:20 PM   #1
How much do new dormers cost?
Looking for cost estimates: I'm adding a third floor master suite and want to build 3 dormers to open up the attic. One is gabled (8 ft x 15 ft), one is a shed (4 ft x 10 ft) and one is doghouse (6 ft x 6 ft).
thanks!
mdavis2678 is offline   Reply With Quote
Old 05-10-2011, 03:22 PM   #2
Framing Contractor
Rewards Points: 120
Dormers can cost a lot more than you think. Extra engineering for loads, extra framing, drywall, window, siding, roofing, etc. Hard for anyone here to give you any idea really.
sixeightten is offline   Reply With Quote
Old 05-10-2011, 03:26 PM   #3
Rewards Points: 5,336
thanks!
To get any accurate estimates, you would need a set of plans to show local contracors who did an onsite inspection.
Ron
Old 05-10-2011, 03:29 PM   #4
Thanks Ron. I did do that and I have the designs. i just wanted to know within the forum if the estimates are out of whack.
Old 05-10-2011, 03:31 PM   #5
thanks Six. all in for a 1450 sq ft house what you would think it would cost? any thoughts? not trying to put you on the spot but just looking for ball park
Old 05-10-2011, 03:31 PM   #6
Rewards Points: 1,010
Impossible for us to answer
Anti-wingnut is offline   Reply With Quote
Old 05-10-2011, 03:32 PM   #7
Framing Contractor
Rewards Points: 120
Were these decide after construction began?
Old 05-10-2011, 04:52 PM   #8
Too Short? Cut it Again!
Have no idea where you are, what building codes are like, how much inspections would cost and no drawings? Too many variables to bid from afar. Guessing would not be fair to you or other reading this thread.
Old 05-11-2011, 01:59 PM   #9
Household Handyman
Rewards Points: 1,408
Just a thought: Ask around in your area as to how often people with dormers have to have repair work done on them such as window sills rotting out, and the transitions from the roof lines leaking causing more damage. Maybe it's just my area but I get over a dozen calls a year from homeowners wanting repairs to dormers or to front porches with water damage caused by improper roof flashing/roof transitions. Something about dormers and South Ga. weather just doesn't work.
Old 05-11-2011, 02:22 PM   #10
No one here has seen the plans.
No one here has visited the site.
I get requests like this when I see a customer about a job.
Customer- How much will this kitchen cost?
Me- Have you picked out cabinets?
Customer-No
Me-Have you decided on appliances, flooring, lighting?
Customer-No, but I just want a ballpark figure.
Me- Are we combining the 2 rooms into one big space
Customer- I don't know yet.. Just a ballpark figure
And on and on and on, ad nauseum.
If you need confirmation, keep calling contractors until you're happy.
Ron
Old 05-11-2011, 03:27 PM   #11
Framing Contractor
You will never get an answer. It's impossible. Besides what difference does it make anyway if someone here does give you a number. You have to go by the estimates you already have.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-11-2011, 04:26 PM   #12
Learning by Doing
Leah Frances's Avatar
$1000 and two weeks. At least that's what I always tell my husband before I start a project
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Tags
attic conversion , dormers
Furnace Installation Cost philstewart HVAC 32 04-13-2014 01:44 PM
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 06:04 AM
Can we get a cost estimate subforum going Will1987 Site Help and Suggestions 8 04-02-2009 07:57 AM
Hot Water Heater Installation Cost philstewart Plumbing 6 10-29-2008 05:05 PM
