How To Miter Cut Exterior Trim Board - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 11:00 AM   #1
Rewards Points: 111
How to Miter Cut Exterior Trim Board
Bought some Azek trim boards to go on the projecting end of a gable. Just underneath the shingle overhang. Question is, how do I make the measure miter cut for the angle at the peak and down by the gutters? Pic attached.
luvdairish is offline   Reply With Quote
Old 07-24-2010, 11:24 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 392
Both angles will be the same as your plumb cut on your rafters.
Jim
BigJim is offline   Reply With Quote
Old 07-24-2010, 11:34 AM   #3
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Take a framing square and a level and at the edge of the roof level the horizontal leg of the square and then use the square to get your rise and run. Get the longest measurement that you can before one of the legs comes off the roof to get the most accurate pitch. It should be a standard pitch - looks like 3/12 to me.
WirelessG is offline   Reply With Quote
Old 07-24-2010, 12:47 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
sliding bevel gauge will do that,make sure you glue the azek joints with the specified pvc cement
why is the tyvek not wrapped around the corners properly?
that gable vent should be flashed just like the windows
Tom Struble is offline   Reply With Quote
Old 07-24-2010, 02:55 PM   #5
Rewards Points: 111
Sorry outdated pic. Here is the latest. Still need to get a new gable vent and window frame for upper right (someone tried to elegantly slam the window in to place )
The Following User Says Thank You to luvdairish For This Useful Post:
Tom Struble (07-24-2010)
Old 07-24-2010, 06:39 PM   #6
ok looking good
Old 07-24-2010, 07:09 PM   #7
kwikfishron's Avatar
Rewards Points: 586
Now thatís some good looking Tyvek.
You could have lined up the letters on the lower right a little better though.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
luvdairish (07-25-2010)
Old 07-25-2010, 03:03 PM   #8
Rewards Points: 562
Isnt the tyvek supposed to wrap inside window openings on both sides and bottom of windows?? and over the nailing flashing on top??? loks like windowswere installed and caulked in then tyveked up to sides and over bottom tyvek that was wrapped as windows were installed.
Using butyl sticky wrap how do you keep the bottom windows corners flat?? I cant stretch it out and cutting it leaves a gap. Wrapping inside bottom sill and trying to get to outside flat siding surface,,,90* turn. Do all of you use a preformed pan for this???
4just1don is offline   Reply With Quote
Old 07-25-2010, 03:33 PM   #9
no
Old 07-25-2010, 03:57 PM   #10
Registered User
Rewards Points: 5,514
That is a 4/12 cut or 18-1/2*. 4" rise per 12" horizontal.
Good: http://www.napleslumber.com/catalogs/HTyvek-81994.pdf
Better: http://www.bostoncedar.com/pdfs/Typa...stallation.pdf
Best: http://www.finehomebuilding.com/how-...x?nterms=63740
Gable vents: pp. 606: http://books.google.com/books?id=Z8a...0vents&f=false
Be safe, Gary
Old 07-25-2010, 04:21 PM   #11
Rewards Points: 111
You can do it either way. Tyvek has instructions for both installing windows before and after WRB. I was going to housewrap first, but someone made the argument that if water gets behind the housewrap, it will leak through the windows (because I caulked and flashed over the housewrap) and I won't know where the water is coming from. Since I bought the house a few months ago and my first discovery was water damage, I errd on the side of caution and backcaulked and flashed the window directly to the plywood. Just a little added protection
The sticky wrap I went with is Tyvek Flexwrap. Really cool product. It flexes into the corners of the sill. I didn't use a back dam or anything behind it on the sill, which I kind of am wishing I did. But I think it will be ok. If I did it over again, I would leave some extra room in the rough opening to use a sill pan or slanted piece of wood to make sure if water did get in, that it would find it's way out. Still very new at this. If you have the option of sill pans, do it. Some might think overkill, but the repair of water damage is not fun.
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
