How To Measure Angles?!?! - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-21-2007, 01:52 PM   #1
How to measure angles?!?!
I have a triangle cut out from my dry wall. It's area is 70". I want to cut a triangle from a drywall sheet I bought from HD and fit it in the triangle in the wall.
Question is, how can i measure the angles to make the cut?
handbanana is offline   Reply With Quote
Old 09-21-2007, 02:16 PM   #2
I face similar challenge before, except mine is not a triangle, but sort of irregular shape ... the way I did it is use some paper to mould the shape and copy it to drywall... may be there is a better way... but this way seems most accurate... I wish there is some thing in the market place to help people easily do that... but didn't aware of any... even moulding a paper on a large irregular shape is a challenge... but that is kind of managable. ...
KUIPORNG is offline   Reply With Quote
Old 09-21-2007, 02:21 PM   #3
47_47's Avatar
Rewards Points: 62
All you need to do is measure all three leg lengths. Layout one dimension on a factory edge from this leg use two tape measures for the other side lengths, where the dimensions meet is your triangle.
47_47 is offline   Reply With Quote
Old 09-21-2007, 05:43 PM   #4
Rewards Points: 5,336
You can use a protractor, you can fold a piece of paper mimicing the angle, you can square off the pieces to make it easier.
How do you plan to block the sheetrock so you can attach it to the wall.
Ron
Old 09-21-2007, 09:29 PM   #5
Home Improvement Guy
ron schenker's Avatar
If the triangle is sticking out a little like a receptacle box put some lipstick on it then carefully press the drywall up to it and you have your outline on the back of the drywall. Then simply cut it out from the back.
ron schenker is offline   Reply With Quote
Old 09-21-2007, 10:32 PM   #6
Custom Cabinet Maker
Just square the cutout,put in a backer pc of wood, cut patch screw into backer then mud it. Way easier,faster
skymaster is offline   Reply With Quote
Old 09-27-2007, 09:31 PM   #7
Rewards Points: 14
Agree on cutting the square and putting in a backer. It's the only way to get it to look like there was not a hole and have it last over time.
msajeep is offline   Reply With Quote
How do you measure CFM? Unregistered HVAC 5 11-12-2011 08:06 AM
How to measure angles? handbanana Carpentry 5 09-16-2007 05:24 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 07:36 PM
Angles for cutting crown mouldings sjrhome Carpentry 14 04-13-2007 07:14 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
