How To Measure Angles? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-15-2007, 09:55 PM   #1
How to measure angles?
say I want to cut a triangle of paneling in my roof. How can I measure the angles so I can make the cut with my miter saw?
handbanana is offline   Reply With Quote
Old 09-15-2007, 10:12 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Dependant on the size of the area....
The key is that you need "reference points" to measure off of.
With a "Triangular" shape, your best bet is to use: either a framing square or a T-square (dependant on the expanse of the area)
Take the corresponding square (Framing or T), place it on the area of the roof that you are trying to determine the measurements of. Next, set one straight "leg" of the square onto a straight edge or line of the triangular shape that you want to measure.
Now, as you look at the square, you have two key points of reference (the legs of the square) to take your measurements from. You have each of these leg segments of the square which are at a perfect 90 degree angle.
Use each "leg" of that sqaure as a reference point to measure your triangle with.
Essentially, you are going to draw out the rough shape of that square you are using on a pad of paper. Then you are going to place the square onto the area and use it to measure off of. Record all your measurements.
When you go to cut out that same shape on your "paneling" ( I think you mean roof sheathing), you will use the same square to lay out and make your marks on the material that you are planning to cut to size....
connect the dots and draw your lines......
.....voila, you should have your triangle!
- Build Well -
Old 09-15-2007, 10:16 PM   #3
Remodeler
MinConst's Avatar
I use a tool like this.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-15-2007, 10:19 PM   #4
I believe that is called an "Adjustable T-Bevel"....
- Build Well -
Old 09-16-2007, 12:19 AM   #5
Rewards Points: 5,336
How are you going to cut your roof with a miter saw? And what are you trying to do?
Ron
Old 09-16-2007, 06:24 AM   #6
Remodeler
MinConst's Avatar
Ron
This is what made me think he is cutting some sort of trim. Maybe on the ceiling (roof).
Web
One Man Shops
How do you measure CFM? Unregistered HVAC 5 11-12-2011 09:06 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
Angles for cutting crown mouldings sjrhome Carpentry 14 04-13-2007 08:14 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
Did I measure this door incorrectly? LRAO Carpentry 9 01-07-2007 09:48 AM
