Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-31-2010, 03:25 PM   #1
Question
how many nails per stud/plate joint?
when nailing studs to the sole or top plate for a wall BEFORE it is stood up, i.e. putting together the assembly on the floor, when shooting nails perpendicular through the sole/top plate and straight into the stud, is it necessary to use two nails or will one suffice?
when i framed my basement, i was nailing 2x4s right in their final setting, i.e. i wasn't assembling walls on the floors but 1 by 1, which didn't make perpendicular/straight into the stud kind of shots but more like toe nailing at an angle, i did use 2 nails for each joint. but i am now building a shed outside and it is different, since i will put each wall together before raising them.
thanks
Old 12-31-2010, 03:50 PM   #2
Use two nails. That will help keep the studs from twisting as they dry. Nails are cheap.
Old 12-31-2010, 06:23 PM   #3
jlhaslip's Avatar
1 nail per each nominal 2" of material, minimum of 2 to avoid the stud from twisting.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 12-31-2010, 07:24 PM   #4
Moderator
Build to minimum Code; http://publicecodes.citation.com/ico...002_par005.htm
P.t. bottom plate on sill sealer (my suggestion) for capillary/thermal break (unless you used plastic v.b. under slab); http://www.greenbuildingadvisor.com/...-building-code
Gary
Clothes taking longer to dry?
Old 01-05-2011, 02:43 PM   #5
+1
That's pretty standard unless you have some kind of funky code you need to meet.
TomB is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
33º vs 35º Nails Dilemma banzaitoyota Tools 1 12-28-2010 07:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 11:05 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
