How To Make This A Closet - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 04:22 PM   #1
How to make this a closet
I just purchased this condo, and in the second bedroom there is this instead of a closet.
I think I want to take this out and make a reach in closet.
It is 20" deep, 66" wide and 72" tall if all the shelving is removed.
That piece of glass is a sliding "window" from the bathroom to the bedroom. I know it's stupid, but I think I'm going to just leave it.
in the top right shelf, is tv and internet wiring for the whole condo
I've never really done work on a house before.
Thanks for any advice.
davidbird is offline   Reply With Quote
Old 09-03-2013, 05:40 PM   #2
Rewards Points: 12,812
Loose the window, it's useless.
Remove everything that's in there.
Frame in where the window was and patch the sheetrock on both sides.
Reframe the opening for two 32" doors.
mae-ling (09-06-2013)
Old 09-03-2013, 08:50 PM   #3
Rewards Points: 274
I think it is fine with window and place for TV no need to remove it.
alexjoe is offline   Reply With Quote
Old 09-04-2013, 08:59 AM   #4
Bill Kearney
Rewards Points: 1,174
I'm guessing the window was someone's idea on how to get natural light into the bathroom. Depending on the structure of that wall you could continue that effect by putting a clerestory kind of window higher up. As long as there's no ductwork or other infrastructure hiding inside that part.
It also looks like that probably used to be a closet anyway. 20" is a bit shallow but should still work (check the depth of your other closets). Just get a set of folding doors that will fit the opening.
wkearney99 is offline   Reply With Quote
Old 09-06-2013, 10:33 AM   #5
Rewards Points: 2,202
Another thing to consider is the floor, does it go through
And if 20" is too shallow - which it probably is especially once you take off room for the doors. . You could do a 6-8" bump out to get the depth you need.
You could also do a built in type unit with cabinet type doors even like what is there, so basically 3 tall lockers then the doors could be on front and not taking up any of the 20".
mae-ling is offline   Reply With Quote
Remove Basement Closet toriafly Remodeling 7 03-28-2012 10:59 AM
Installing a closet bar on an angled wall Nathan0115 Building & Construction 10 06-28-2010 09:31 PM
Modifying studs below staircase to open up where a closet used to be Veisner Remodeling 8 03-17-2010 05:33 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 09:22 AM
Running romex along a wall in a closet Red Squirrel Electrical 16 10-02-2009 09:44 PM
