How To Make Beveled Edge Countertop - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 09:52 PM   #1
Rewards Points: 14
how to make beveled edge countertop
I have made Laminate countertops before but I thought I would like to make a countertop with a small bevel on the corker. So the countertop would be made normal but instead of a 90 degree edge where you use laminate trimmer to finish the material, the edge would consist of a 45 degree with a 1/4 inch or so laminated followed by another 45 degree to compete the 90 corner.
is there a special bit that can be used on a router to produce this?
abedj is offline   Reply With Quote
Old 09-08-2009, 06:17 AM   #2
Not an esay thing to do outside of a full production facility, but they make premade bevel edge for that very prupose. Not sure of minimum quanities, but you can get any color face with any color bevel. Check where laminate, countertop supplies are sold, but likely not big box.
Old 09-08-2009, 07:12 AM   #3
Rewards Points: 14
Thanks for the info. I will take your advice and look outside my skills. My next thought was to use bullnose and a biscuit joiner.
Old 09-08-2009, 08:58 AM   #4
Home Remodeler
Rewards Points: 164
I buy my beveled edge from a smaller hardware store. Not all style laminates are available. They come in 12 foot lengths and run about $50. I would google countertop beveled edge for more info.
mikey48 is offline   Reply With Quote
Old 09-08-2009, 02:39 PM   #5
Rewards Points: 14
Thanks Mikey If I understand you make your own counter tops and then buy the bullnose from the hardware store and then attach the bullnose to the countertop?
Have you done solid surface edging to laminate countertops? I have been reading up on that and it sounds like that is done with glue.
Old 09-09-2009, 06:31 AM   #6
You didn't mention solid surface before. That is a different story. Yes, there are router tools for doing that, but for solid surface they must be carbide. 1/2" shanks have better stability than 1/4" but need a router that will allow them.
Old 09-09-2009, 10:38 AM   #7
Home Remodeler
Rewards Points: 164
I have not done solid surface. I buy the laminate and beveled edge at the same time.
People love the look and the price compared to granite.
Tags
bevel edge countertop
Edge Flooringwhat the heck? sammythebull Flooring 29 03-28-2008 10:57 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Drip edge on a shed roof. Scott Roofing/Siding 2 10-04-2006 07:22 AM
Countertop sink hole Grebus Remodeling 1 08-31-2005 10:09 PM
