Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-18-2012, 10:52 AM   #1
How long does stain and poly last in the can?
I'm working on refinishing an antique table and I'm finally ready to stain and poly it. I already have a can of Minwax stain and a can of Duron poly from about 8 years ago when we built our house. Is this stuff still okay to use for a table top? After putting this much work into refinishing the table top I don't want to put something on it that isn't going to bond well. I also have two new cans of Minwax stain and Minwax poly that I purchased yesterday... but if I can use the old stuff and expect it to hold up I can take the new stuff back.
Thanks for any suggestions!
the68 is offline   Reply With Quote
Old 03-18-2012, 01:29 PM   #2
Ironlight's Avatar
Pretty definitely not. The prevailing wisdom is that polyurethane has a shelf life of two years, less if previously opened.
I'm not sure about the stain. I think if you test it and it dries adequately then you'll be fine but I'm no coatings expert.
Ironlight is offline   Reply With Quote
Old 03-21-2012, 05:54 AM   #3
Remodeling Contractor
stain will last indefinitely but settles. A lot of mixing by stirring will be needed. Poly has a one to three year shelf life depending on type.
Removing poly and stain canoes Painting 22 03-05-2012 08:04 PM
Can I still Stain after wipe-on Poly? jennyusmc Painting 5 03-06-2011 01:36 PM
Can you use a poly stain on an exterior door that is covered with a porch insfan1 Remodeling 1 09-11-2010 07:56 PM
Stain over Poly? megkatgre Flooring 3 04-27-2010 01:07 PM
can I just stain and poly my old wood floors? hollyworthy Flooring 3 07-23-2008 02:55 PM
