How To Layout Sheathing On A 10' Wall? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 09:45 PM   #1
Rewards Points: 113
How to layout sheathing on a 10' wall?
Hi guys,
I'm a beginner working on a shed project and just hit my next stumbling project. My shed is roughly 10'x10' with 8' tall walls. So, I basically have 320 sq. ft. of wall to cover. So I've focused on layouts that use 10 sheets of OSB. Thus far, I've considered laying out the sheets vertically, 4', 4', and 2', as one option. The other is horizontal method, would be a 8' and 2' strip and a 4' and 6' strip. From what I read, it sounds like horizontal is much stronger which makes sense. For my horizontal, option I was concerned about the small 2' x 4' section and having to make 6 cuts vs 2 with the vertical approach. So, my question is which is the better option or have I overlooked something better?
S
mklein49 is offline   Reply With Quote
Old 08-28-2013, 11:28 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
why not go 8' vertical? studs at 24" o.c.?
just a thought ..... good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-28-2013, 11:48 PM   #3
Jack of all Trades
lifestooshort81's Avatar
Rewards Points: 77
I don't know if its a standard but whenever I layout sheet goods the long edge always goes perpendicular. I was 'taught' to NEVER "stand" your sheet up. Without know the exact answer as to why I can make an educated guess and say it has to do with stability. Same way you might make a cross brace as a support rather than a straight brace. Make sense?
Unfortunately you're going to have to go with a 4' 4' & 2' don't forget to reverse that pattern when you hang the next course of sheathing. You don't want overlapping seams!
hope this helps...just my $0.02
Al C
lifestooshort81 is offline   Reply With Quote
Old 08-29-2013, 08:07 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
the only time I consider putting sheathing sideways is on a gable wall and not always then. sheathing installed vertically works better and provides lateral support
hand drive is offline   Reply With Quote
Old 08-29-2013, 09:42 AM   #5
Rewards Points: 113
I have already framed the walls 16" o.c.. I think I would still be ok going 8' vertical, though.
Old 08-29-2013, 09:43 AM   #6
Rewards Points: 113
Al C
I was thinking 8' and 2' on the base course and 4' and 6' on the top course. What do you think of that approach?
Old 08-29-2013, 09:49 AM   #7
GBrackins's Avatar
The American Wood Council has determined it does not matter whether your sheathing is laid horizontal or vertical when it comes to shear strength.
shear strength comes from nailing the edges of the sheathing into the studs (not in the field of the sheet).
you get more panel edges aligned with studs when the panel is installed vertical. if the panel is installed horizontal you'd need to install blocking along the panel edges to be able to install the same number of nails.
Gary
Old 08-29-2013, 12:17 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,244
going horizontal with sheets locks more studs together to make fora stronger wall though. vertical sheets are stronger for resistingt uplift
woodworkbykirk is offline   Reply With Quote
Old 09-07-2013, 04:34 PM   #9
MT Stringer's Avatar
Rewards Points: 254
In 2002 I built a 10 x 12 storage building similar to what you might find on display at your local big box stores. I used the T-111 looking siding for the shed, and naturally it went up vertical (16" OC). So far we have been through two hurricanes (Rita and Ike) and I haven't even lost a shingle. Had lots of damage to the roof on our house but the little shed is still standing. Even the insurance guy was impressed. The fence has been replaced each time also.
Mike
MT Stringer is offline   Reply With Quote
The Following User Says Thank You to MT Stringer For This Useful Post:
oh'mike (09-07-2013)
wall sheathing question markharmon Building & Construction 32 05-11-2013 01:43 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 09:48 PM
Newbie needs your advice on OSB wall sheathing bjqq Building & Construction 13 01-24-2013 03:38 PM
Painting exterior plywood wall sheathing hiphi45 Building & Construction 2 12-24-2011 12:12 PM
rafter birdsmouth and wall sheathing ??? Clutchcargo Building & Construction 4 07-10-2009 08:47 PM
