-   -   How to layout sheathing on a 10' wall? (http://www.diychatroom.com/f14/how-layout-sheathing-10-wall-186136/)
mklein49 08-28-2013 09:45 PM
Hi guys,
I'm a beginner working on a shed project and just hit my next stumbling project. My shed is roughly 10'x10' with 8' tall walls. So, I basically have 320 sq. ft. of wall to cover. So I've focused on layouts that use 10 sheets of OSB. Thus far, I've considered laying out the sheets vertically, 4', 4', and 2', as one option. The other is horizontal method, would be a 8' and 2' strip and a 4' and 6' strip. From what I read, it sounds like horizontal is much stronger which makes sense. For my horizontal, option I was concerned about the small 2' x 4' section and having to make 6 cuts vs 2 with the vertical approach. So, my question is which is the better option or have I overlooked something better?
S
GBrackins 08-28-2013 11:28 PM
why not go 8' vertical? studs at 24" o.c.?
just a thought ..... good luck!
lifestooshort81 08-28-2013 11:48 PM
I don't know if its a standard but whenever I layout sheet goods the long edge always goes perpendicular. I was 'taught' to NEVER "stand" your sheet up. Without know the exact answer as to why I can make an educated guess and say it has to do with stability. Same way you might make a cross brace as a support rather than a straight brace. Make sense?
Unfortunately you're going to have to go with a 4' 4' & 2' don't forget to reverse that pattern when you hang the next course of sheathing. You don't want overlapping seams!
hope this helps...just my $0.02
Al C
hand drive 08-29-2013 08:07 AM
the only time I consider putting sheathing sideways is on a gable wall and not always then. sheathing installed vertically works better and provides lateral support
mklein49 08-29-2013 09:42 AM
I have already framed the walls 16" o.c.. I think I would still be ok going 8' vertical, though.
mklein49 08-29-2013 09:43 AM
Al C
I was thinking 8' and 2' on the base course and 4' and 6' on the top course. What do you think of that approach?
GBrackins 08-29-2013 09:49 AM
The American Wood Council has determined it does not matter whether your sheathing is laid horizontal or vertical when it comes to shear strength.
shear strength comes from nailing the edges of the sheathing into the studs (not in the field of the sheet).
you get more panel edges aligned with studs when the panel is installed vertical. if the panel is installed horizontal you'd need to install blocking along the panel edges to be able to install the same number of nails.
woodworkbykirk 08-29-2013 12:17 PM
going horizontal with sheets locks more studs together to make fora stronger wall though. vertical sheets are stronger for resistingt uplift
MT Stringer 09-07-2013 04:34 PM
In 2002 I built a 10 x 12 storage building similar to what you might find on display at your local big box stores. I used the T-111 looking siding for the shed, and naturally it went up vertical (16" OC). So far we have been through two hurricanes (Rita and Ike) and I haven't even lost a shingle. Had lots of damage to the roof on our house but the little shed is still standing. Even the insurance guy was impressed. The fence has been replaced each time also.
Mike
