Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-07-2011, 08:31 PM   #1
Question
how to install wood molding around window
I have a 14 year old house~Anderson windows-OK SHAPE~ Prob is I have stained wood & now want white wood work around window.How hard is it to take off old stained wood & install white, as well as paint stained window to white.
ctsgroi is offline   Reply With Quote
Old 09-07-2011, 08:42 PM   #2
STAFF
BigJim's Avatar
Why not just scuff the finish and paint it?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
ctsgroi (09-07-2011)
Old 09-07-2011, 09:26 PM   #3
HI!
Isnt it hard to paint over stained? lots of sanding? and any tricks to painting the wood that holds the panesof glass?
Old 09-07-2011, 09:53 PM   #4
It's not hard to remove the trim...just expensive to replace it. My old house is filled with trim that was originally stained. Since that time it has been covered with numerous coats of solid paint. In a few instances, I stripped it down to the original finish, scuffed it up good and then primed it with KILZ. Then another light sanding, and finished with quality semi gloss.
It came out very good in my opinion.
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
BigJim (09-07-2011)
Old 09-08-2011, 03:48 PM   #5
Has anyone ever used a product at Sherwin Williams that can be painted over any surface such as stained wood- it will act as a primer but no sanding has to be done on the wood...
Old 09-08-2011, 03:54 PM   #6
Tileguy
Bud Cline's Avatar
I gotta tell ya...this is the first time I have ever heard of anyone wanting to replace window trim simply because it is stained and they want it painted. Seems a little ridiculous to me. If the trim is stained then it is very likely it also has a clear coat of (something) over it and would easily be paintable. The fact that it was previously stained means absolutely nothing.
Someone please explain to me the sanity of doing such a thing. I'm all ears. Maybe I'm missing something.
Old 09-08-2011, 05:14 PM   #7
Well Bud~ the trim I have is thinner & would like thicker, Im a woman & tastes change
I think I will attempt to paint the stained wood even if my husband has threatened to leave me if i do so~ just need a change
The Following User Says Thank You to ctsgroi For This Useful Post:
Tom Struble (09-08-2011)
Old 09-08-2011, 05:23 PM   #8
Tileguy
Bud Cline's Avatar
Women!!!
Old 09-08-2011, 05:28 PM   #9
Tom Struble's Avatar
she told you ''bud''
Tom Struble is offline   Reply With Quote
Old 09-08-2011, 05:35 PM   #10
Tileguy
Bud Cline's Avatar
Old 09-08-2011, 05:47 PM   #11
Originally Posted by ctsgroi View Post
...the trim I have is thinner & would like thicker, ...
That is a completely different question than the one originally asked. Removing the trim is actually pretty easy, just go slow and careful. Be prepared though...... mill work is expensive.
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Window Install? sod Building & Construction 3 10-26-2008 08:02 AM
How do I install a window tripower Building & Construction 3 10-24-2008 05:47 PM
