Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-23-2011, 02:06 AM   #1
How to install trim around stair treads
We recently purchased a home that had some renovations done to it.
drywall was installed on the stairwell walls and they cut around the stair treads so now there is a gap where the drywall and stairs meet.
Also the bullnose is rounded so unsure as to how to cut molding to go around this and it still look good. Some of the gaps are pretty big so cauking is not an option. Any Ideas on what to do?
jingle is offline   Reply With Quote
Old 09-23-2011, 06:40 AM   #2
Super Moderator
Post a picture---sounds like they planned on carpet---
Old 09-23-2011, 10:25 PM   #3
Install base trim following treads and risers. Pieces will be appox. one foot long each with 45's(+-) on each end. You must cut nosing out the thickness of you trim with flush cut saw to the riser. Looks really nice and custom when someone takes time to do a nice job.
framingrailman is offline   Reply With Quote
Old 09-24-2011, 12:10 PM   #4
I don't know why you would have the drywall wrapped around the treads and risers. The treads and risers are in a stringer, why wasn't the wallboard brought down to that? Then you install a molding to cover the stringer wallboard interface.
Ron
B. Franklin 1759
Old 09-24-2011, 06:52 PM   #5
STAFF
BigJim's Avatar
Jingle, you can install a skirt board, here is a good way to do it.
Stairway skirt board template - easy
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 09-24-2011, 07:03 PM   #6
Super Moderator
WOW--Good find Jiju---
BigJim (09-24-2011)
Leveling Stair Treads JDScalf Carpentry 16 09-11-2011 08:57 AM
How Do I Install This Stacked Trim? benjamincall Building & Construction 14 05-29-2011 02:18 AM
How to install granit treads and railing lsyrkin Tiling, ceramics, marble 0 05-08-2011 09:43 PM
How to install granit treads and railing lsyrkin Building & Construction 1 05-08-2011 08:06 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
