How To Install Skins ??? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 09:25 PM   #1
How to install skins ???
Hey Guys,
I have a 4x8 cabinet skin that I need to cut and install to the back of the cabinets shown. Should I use PL200 glue and then screw from inside the cabinet to pull it tight? Or is there a better procedure. I will also be installing decorative panels over it. Thanks for any advice you have.
zman22 is offline   Reply With Quote
Old 04-06-2010, 09:49 PM   #2
jlhaslip's Avatar
Rewards Points: 2,748
that would work
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-07-2010, 07:25 AM   #3
DIY staff
Rewards Points: 7,174
Brads or pins placed where the trims and panels will hide the holes would be a simple solution.
The glue will do the holding--you just need to keep the panel flat and in place till the glue dries.
--Mike--
Old 04-07-2010, 08:46 AM   #4
cut location...
OK, Thanks for the replies.
Now, should I cut the skin to stop just before the last cabinet which allready is finished as you can see in the picture. I ask this because the decorative panel on that last cabinet will be slightly in compared to the others.
Old 04-07-2010, 09:34 AM   #5
DIY staff
I'd made the 'skin' the full length--with a toe kick cut out.(on the right hand end) If you don't --how would you hide the raw cut edge?
Old 04-07-2010, 09:45 AM   #6
Old School
Willie T's Avatar
You don't choose to use contact cement?
Willie T
Old 04-07-2010, 10:08 AM   #7
raw edge
Didnt think about the raw edge by the toe kick. However, if I am looking at the end "book shelf" cabinet straight on, wouldnt the raw edge show above the toe kick? How would I hide that? I'm probably just not getting something here.
Old 04-07-2010, 10:20 AM   #8
contact cement?
"You don't choose to use contact cement? "
Didnt choose anything yet. What's best?
Old 04-07-2010, 10:39 AM   #9
DIY staff
Is the 'skin' 1/4 inch? If it is the face frame on the right end cabinet will hide the edge.
as to the toe kick cut out for the right end cabinet--the toe kick board will cover the cut--stain or paint the end of the toe kick to match.
--Mike--
Old 04-07-2010, 11:57 AM   #10
got it...
Starting to get it all now. THANKS a MILLLLLIIOOONNNNN
Old 04-07-2010, 06:03 PM   #11
Unhappy
face frame on the right issue
"Is the 'skin' 1/4 inch? If it is the face frame on the right end cabinet will hide the edge."
Have an issue Mike, the skin is 1/4 inch but the face frame on the right end cabinet does not have a lip. It's pretty much flat on the edge. So, the skin will reveal the unfinished end. In other words there is no lip to bring the skin up to.
Should I go back to the original plan installing the skin only over the other cabinets and not the end one. Then the deco panel on the end cabinet would technically be the guy that hides the unfinished side of the skin.
Old 04-07-2010, 06:21 PM   #12
jlhaslip's Avatar
use an outside corner molding to hide the exposed edge
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
