How To Install Interior Door Slab Hinges. - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 04:57 PM   #1
How to install interior door slab hinges.
I need to install 10 Masonite interior door slabs. What is the best way to mortise the hinges. I've read about trouble with using the hinge templates for a router, but am afraid to try my hand at chiseling them out. The hinges have a 5/8 inch radius on them which makes the process a little harder. What does the average carpenter use on a daily basis ? Any help would be greatly appreciated.
tmbrink is offline   Reply With Quote
Old 05-02-2009, 08:35 PM   #2
Old School
Willie T's Avatar
We mostly use a router and templates. Once in a while when I'm too lazy to set the template up, I'll use a hammer-tapped butt marking gauge along with a utility knife, then chisel it the rest of the way.
Willie T
Old 05-02-2009, 10:17 PM   #3
Rewards Points: 5,336
Why don't you do yourself a favor and just get square hinges.
There is no, "trouble" with a router if you know what you're doing.
If you don't want to use a router or a chisel, hire someone who can use a tool.
Ron
Old 05-03-2009, 02:26 PM   #4
Registered User
Rewards Points: 526
I agree with Ron. Hint: one edge of each door is beveled slightly, to close on the latch side without binding. Be safe, G
Old 05-03-2009, 02:57 PM   #5
10 doors, 2 or 3 hinges each??
do you have a router if so go to any home center and get the porter cable hinge template. comes with the router bit. very easy to use for square or round hinges and costs about $25. bucks.
How to install interior door slab hinges.-porter-cable-59370-rw-80526-25836.jpg
II Weeks is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 10:16 PM
