How To Hide Shims On The Wall Cabinet? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 02:14 AM   #1
How to hide shims on the wall cabinet?
Because of the wall, shim have to be used for the first cabinet on the left side which is at the end no other cabinet will be connected to it. How to hide the shims on this cabinet?
Thanks very much for any suggestions.
irenelj78 is offline   Reply With Quote
Old 03-04-2012, 02:37 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
It's called "scribe", a 1/4" x 3/4" (or a little smaller) flat trim with one corner rounded off.
It's made just for this.
Lowes or your local trim shop or lumber yard has it.
titanoman is offline   Reply With Quote
Old 03-04-2012, 02:50 AM   #3
Fantastic~!!!!Thanks so much. My headache is gone now
Old 03-04-2012, 11:44 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,356
sometimes a finish panel can be installed, its simply a slightly larger panel of matching plywood that gets cut to fit hiding any gaps and eliminates a small molding at the edge which can sometimes look out of place
woodworkbykirk is offline   Reply With Quote
Old 03-05-2012, 07:13 AM   #5
Thanks very much. How to get a panel that has the same color of the cabinet? There is also custom color stain available?
Old 03-05-2012, 02:09 PM   #6
The cabinet manufacturer will offer them to match (or close to it)
yogi_bear_79 is offline   Reply With Quote
Old 03-05-2012, 06:20 PM   #7
Rewards Points: 2,212
If it is a wood cabinet and you can get the same wood a really good painter can match the stain. Have done it lots in insurance work.
mae-ling is offline   Reply With Quote
Old 04-03-2012, 05:11 PM   #8
Haverhill Trade 1965
shims
If they are factory built cabinets, look at the end of the cabinet where the front frame joins the end. If it projects beyond the end about 3/16" then like woodworkbykirk said, it should have a "skin". The manufacturer should have them that match the finish of the cabinets. They can be glued on with a spreadable adhesive for complete contact, or contact cement , (if you have no pilot light in the stove), to avoid any nails. If the size of a scribe is too noticeable try a small piece of quarter round molding.
Duckweather is offline   Reply With Quote
Old 04-03-2012, 11:09 PM   #9
Make sure the skin is 12" wide and not 11 1/4" as you'll need room to scribe. If not, you'll need to purchase a wider skin
mrgins is offline   Reply With Quote
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 10:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
