How To Hang Something From Vinyl Siding House - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 11:21 PM   #1
Rewards Points: 308
How to hang something from vinyl siding house
Looking to probably build an arbor above our garage doors but cannot figure how to attach it to the actual house. Should I expect to cut out part of the vinyl? Or hang on the vinyl? What is protocol?
smokey847 is offline   Reply With Quote
Old 05-18-2013, 01:51 AM   #2
Rewards Points: 2,212
Is this on a Gable end?
Usually peel off the siding and attach directly and reinstall needed flashings and siding
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
woodworkbykirk (05-18-2013)
Old 05-18-2013, 07:58 AM   #3
Rewards Points: 14,000
Got a picture or web site to get an idea of what it is your trying to do?
Old 05-18-2013, 08:04 AM   #4
Old 05-18-2013, 08:22 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
never hang anything off of vinyl it has no holding power. you need to mount a j-block on the wall first then side into the jblock
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
joecaption (05-18-2013)
Old 05-19-2013, 09:43 PM   #6
take off the siding, and put a ledger board on the house, build whatever you want, reinstall siding and flash it
ubcguy89 is offline   Reply With Quote
Old 05-19-2013, 10:03 PM   #7
Jblocks around here are for lights and such, how would you use that for mounting a ledger board?
Old 05-20-2013, 01:56 PM   #8
ahhh didntt see the part about the ledger. in that case you have to remove the siding then install the ledger . then install j channel around the ledger and re install the siding
Old 05-21-2013, 09:53 PM   #9
Msradell's Avatar
Rewards Points: 268
It would be much easier to just set posts to hold the arbor instead of attaching it to the house. In addition, if you do this, it would give you the option of removing the arbor at a future time if your tastes changed.
Msradell is offline   Reply With Quote
Old 05-21-2013, 10:04 PM   #10
Roofmaster
Rewards Points: 2,210
I thought an arbor was a stand alone trellised arched entry into a garden area? What would something like this be doing above a garage door?
Found Cardboard under vinyl siding phage Roofing/Siding 4 07-20-2010 08:07 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
