| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Choose Drywall
by eHow.com
The drywall you choose for your next home improvement project depends upon the room in which you are planning to work. Drywall, often referred to as wallboard, is available in different varieties, lengths and widths. Here's how to choose drywall for your... Read More »
Checking Corners on a Home Quality Inspection
by Expert Village
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality walk through on this house. Your corners come together in the home. You know look at the way those come together and make sure that they... Read More »
How to Measure When Installing Drywall
by eHow.com
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
How to Do a Fantasy Draft in Madden 08: Round 3
by Expert Village
Hey this is Phil Coonrod on behalf of Expert Village. Today we're going to talk about Madden 08. Okay we've taken our shut down corner so far, we're here in round three. We've taken our shut down corner, and we got our, our, our tackle that we're going... Read More » Feng Shui is a design technique that uses the five elements of wood, fire, earth, metal and water to bring positive energy into a designed space. Because its purpose is to create a balanced environment, using feng shui to decorate your living room will... Read More »
