How To Frame An Open Door Opening - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 11:12 AM   #1
How to frame an open door opening
I am finishing my basement and have a number of door opening that I will not be installing doors. The rough opening is 2x6. I have installed sheet rock all the way to the door opening. That means the opening is now
6 1/2 inches wide. I planned on putting a 1x6 on the opening and then framing the outside. However, that will not work because a 1x6 is not wide enough. How do you do this? I know I could just sheetrock it but I wanted an actual frame.
tri-again is offline   Reply With Quote
Old 09-11-2011, 11:27 AM   #2
Framing Contractor
6 1/2 inches wide. I planned on putting a 1x6 on the opening and then framing the outside. However, that will not work because a 1x6 is not wide enough. How do you do this? .
Buy a 1x8 and rip it down.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-11-2011, 02:21 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
I you want high end stuff, go with custom jambs:
http://www.hardwooddoorandbevel.com/..._jambstock.htm
Or if you are going to paint, use 1 x 8 Poplar and rip to just oversize. Plane or sand to final dimension. Poplar is very stable and takes paint very well.
Coastal South Carolina
Old 09-11-2011, 06:47 PM   #4
Rip the 1x8 on a table saw. I just did this with a 1x6 to rip down to 4 3/4 to build jambs for an old, old garage.
If you have no access to a table saw, you could also snap a chalk line down the 1x8 and use a hand held 5 1/4 circular saw to cut straight down the line, although it might not make a perfectly straight cut, you could then use a finish sander to make it pretty.
oldhouseguy is offline   Reply With Quote
Old 09-11-2011, 07:17 PM   #5
kwikfishron's Avatar
Rewards Points: 1,002
If you have to rip something like a door jamb with a circular saw then clamp a straight edge to the board and guide the saws table against that.
You'll have to offset the straight edge the distance between the saw blade and the edge of the table.
kwikfishron is online now   Reply With Quote
Old 09-12-2011, 06:31 AM   #6
Now, THAT is a really good idea!
gas furnace wont let gas vave open hutch07 HVAC 5 11-15-2010 03:09 PM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 02:23 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
Sistering 2x4's on Frame wrldruler Building & Construction 4 08-25-2008 08:47 AM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 02:38 PM
