How To Frame Diagonal Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 06:16 AM   #1
Rewards Points: 274
how to frame diagonal wall
No walls are up yet, does this involve ripping corner studs at an angle on a table saw where diagonal walls meet?
ugabulldog is offline   Reply With Quote
Old 09-30-2013, 06:34 AM   #2
Rewards Points: 13,748
No need to really, but would not do any harm.
Old 09-30-2013, 06:48 AM   #3
Rewards Points: 274
So you are saying all I need to do is cut top and bottom plates on an angle and line up corner stud with plate?
Old 09-30-2013, 06:58 AM   #4
DIY staff
Rewards Points: 7,174
It all depends on the angle---if the corner stud gap is close enough for attaching a corner bead when the drywall is installed--then you are probably okay---
Make sure the studs are stable and wont pop your drywall corners by moving---
I usually add a ripper to the opening so the outside corner can't flex.
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 09:48 PM
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
