-   -   how to frame diagonal wall (http://www.diychatroom.com/f14/how-frame-diagonal-wall-187829/)
ugabulldog 09-30-2013 07:16 AM
No walls are up yet, does this involve ripping corner studs at an angle on a table saw where diagonal walls meet?
joecaption 09-30-2013 07:34 AM
No need to really, but would not do any harm.
ugabulldog 09-30-2013 07:48 AM
So you are saying all I need to do is cut top and bottom plates on an angle and line up corner stud with plate?
oh'mike 09-30-2013 07:58 AM
It all depends on the angle---if the corner stud gap is close enough for attaching a corner bead when the drywall is installed--then you are probably okay---
Make sure the studs are stable and wont pop your drywall corners by moving---
I usually add a ripper to the opening so the outside corner can't flex.
