How To Frame A Curved Porch Roof - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 11:43 PM   #1
How to frame a curved porch roof
Hello, I'm adding a porch and am wondering how you frame a roof like on the front porch of this house. It's a cathedral ceiling, but the beam is not supported on the front or doesn't appear to be and there are no collar ties to stop the sides from pushing out. Does anyone have any information on how this would be framed?
http://archadeck.files.wordpress.com...y-maryland.jpg
hick23 is offline   Reply With Quote
Old 05-14-2013, 12:08 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
they could have used rafter ties. a rafter tie is a means of constructing a structurally sound roof without the need of a ridge beam or ceiling joists. basically if you measure from the bird's mouth (where rafter sits on beam) to the ridge a rafter tie would be located in the lower 1/3 of that distance. it is normally installed on the side of the rafters to connect them together and looks like the letter "A". if the rafter tie is located at the bird's mouth we would normally refer to this as a ceiling joist.
you would then frame the barrel vault ceiling using the rafters and rafter ties.
Hope this helps.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-14-2013, 04:57 AM   #3
I frame barrel vaults, most of the time I use 4x8 to sheathing make my arches. then make multiple patterns. then strap it with ferring. hope that helps
roofguy is offline   Reply With Quote
Old 05-14-2013, 06:40 AM   #4
Framing Contractor
Rewards Points: 120
The front arch there also serves as a collar tie.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
oh'mike (05-14-2013)
Old 05-14-2013, 07:15 AM   #5
DIY staff
Rewards Points: 7,174
Front of the arch is often made of a doubled sheet of 3/4" ply (1 1/2") that is plenty of strength to keep the structure straight----
Old 05-14-2013, 08:05 AM   #6
Old School
Willie T's Avatar
Interesting. I'd almost bet that roof would be done with small scissors trusses today.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
GBrackins (05-14-2013)
Old 05-14-2013, 11:14 AM   #7
GBrackins's Avatar
scissor trusses would certainly work!
Gary
Old 05-14-2013, 10:25 PM   #8
I like the idea of the plywood. I'm not too sure if I could get scissor trusses that could spand the 9 feet I have to span but I will look into it.
Old 05-15-2013, 08:38 AM   #9
Old School
Willie T's Avatar
Do you feel it is too short a distance?
Willie T
Old 05-15-2013, 10:35 AM   #10
Rewards Points: 2,212
I could get Trusses including scissor trusses any size I wanted.
The idea of double 3/4inch plywood for the gable end is good.
mae-ling is offline   Reply With Quote
Old 05-15-2013, 11:09 AM   #11
GBrackins's Avatar
if you're looking to use plywood for the ceiling of a barrel vault ceiling I'd recommend checking out the required bending radii for plywood from the Engineered Wood Association.
http://www.apawood.org/level_c.cfm?c...s&pubGroup=tch
sometimes it is easier to use two layer of thinner plywood that attempting to bend a thicker panel.
Gary
Old 05-18-2013, 05:23 AM   #12
Lord of Slums
Rewards Points: 1,974
wow, who put all those plumbing vents on the front of that house.
mj12 is offline   Reply With Quote
Old 05-18-2013, 06:23 AM   #13
DIY staff
I'll meet you there with a case of Hula Hoops --we can play 'roof top ring toss'---
Tags
curved roof porch framing
New roof for paver porch choisnec Building & Construction 1 02-12-2012 09:21 PM
Porch roof abagoz Building & Construction 0 03-17-2011 05:59 PM
Tied in Porch Roof to Existing Roof - Leaking bharling Roofing/Siding 29 03-08-2011 05:06 AM
Porch roof tie in question dabensys Carpentry 6 08-11-2008 02:46 PM
Roof over porch in double valley doitall Building & Construction 1 04-25-2006 11:33 AM
