How To Fix Thermal Break In Cinder Blocks - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 06:53 PM   #1
How to fix thermal break in cinder blocks
I removed some old brick from the front of my house and found open cinder blocks underneith. I'm affraid this is a thermal break so I 'd like to fill it, but I'm wondering if I could pour some sort of insulation in them (like polystyrene beads) then put some concrete over it to cap it off? The holes look like they go about 4 feet deep. Any thoughts?
tsg234 is offline   Reply With Quote
Old 07-15-2011, 12:01 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
You could. It's not really a thermal break. More like an air infiltration issue. The styrofoam will stop some air convection through the cores, but won't really insulate much. I trust you're going to put the brick back into place. If so, you may want to look at putting a through-wall flashing on top of the block to prevent any moisture or condensation from reaching the framed wall along with some weeps on the bottom course of brick.
Old 07-15-2011, 12:32 PM   #3
AGWhitehouse's Avatar
The block itself is the thermal break. Filling the cores won't remedy that, it may help thermal efficiency slightly though. If you want really insulate this wall and removal thermal breaks then rigid foam sheathing is the way to go...
AGWhitehouse is offline   Reply With Quote
Tags
insulation , thermal break
Can cinder blocks be ground and used for gravel drive? Bill007 Building & Construction 3 06-20-2011 09:55 AM
How to prevent cinder blocks from "popping out" Red Squirrel Building & Construction 4 03-21-2010 09:11 PM
heat loss through hollow cinder blocks diy4life Building & Construction 11 11-19-2009 10:37 AM
cinder blocks under tub? Leoskee Building & Construction 8 09-03-2009 04:52 PM
Filling concrete cinder blocks Clutchcargo Building & Construction 7 07-25-2008 06:54 AM
