How To Fix Stairs, Missing Rail - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-10-2014, 04:15 PM   #1
Rewards Points: 640
How to fix stairs, missing rail
Our stairs from the 1st to second floor are dangerous for young kids, you can literally walk from the steps off a closet.. pictures are attached..
We have no continuous or even a single hand rail from the top balcony to the 1st landing.
Stairs are already at the minimum width... 36"
How would you go about fixing this? I'm looking for all options and ideas.
How to fix stairs, missing rail-dsc_8490.jpg   How to fix stairs, missing rail-dsc_8492.jpg   How to fix stairs, missing rail-dsc_8493.jpg
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 07-10-2014, 04:18 PM   #2
Rewards Points: 640
another note: we are already planning on replacing all the rails, balusters, treads and risers and converting to hard wood steps. right now the balusters are 6" apart, code requires max 4" here... so there is a lot of stuff already planned to be fixed so big changes aren't an issue, except if they are outrageously expensive ontop of the existing replacement costs *lol*
Old 07-10-2014, 04:32 PM   #3
kwikfishron's Avatar
Rewards Points: 370
I look at those pictures and all I can see is what an eyesore that closet is (imo). Any chances of getting rid of it as part of the stair remodel?
kwikfishron is online now   Reply With Quote
Old 07-10-2014, 05:37 PM   #4
Rewards Points: 640
It's being considered... not sure why they designed the house this way, the stairs to the basement on the original plan had the same dumb closet but they never built it out down there
at the very least the closet needs rebuilt.. it's not even square! on the side with the thermostat / bell the bottom littearly bows out where the steps to the basement is to the far end of that wall there is a 3" curve to the wall on the bottom plate of the wall
Old 07-10-2014, 05:43 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
+1 on getting rid of the closet, it looks totally out of place, it is the focal point as soon as you enter the room.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-11-2014, 07:13 AM   #6
Rewards Points: 640
even if I get rid of the closet though, it's a huge task..
the switch there is a 3-way and it's wires run in the floor joists 18ft away to the other switch and the ceiling in the basement was dry-walled and you'd need to either put a junction box somewhere to extend the line or rerun the line... the thermostat not such a big deal as the wire runs the opposite way so moving it back would actually give me more wire... and there is a few feet extra in the wall thinking that could happen someday... the door bell is in the same situation extra wire.
even if the closet went, I'd have to extend the stairs out a few inches to meet code for the rail so I don't encroach on the 36" minimum width... any ideas on how to do that? don't exactly want to have to reengineer the entire stair case since it's an L shape, moving it out would make odd issues with the platform landing area...
Old 07-11-2014, 07:43 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
These stairs are not to code, the inspector must have been asleep that day.
If the closet was removed you would just continue the rail system as it is at the bottom of the stairs. The framing for the closet against the stairs could be modified to be the structure for the rail system. It is really simple just a lot of work. As for the electrical, if you decide to remove the closet, you might make a new thread in the electrical forum.
Let us know which direction you wish to go and we will go from there.
Edit* There would be no problem with the mid landing by continuing the rail system as it is at the bottom of the stairs. I would suggest changing the rails at the top to side mount newels instead of top mounted so the rail and balusters would flow instead of jutting to the side.
Jim
Old 07-11-2014, 07:48 AM   #8
Rewards Points: 640
ah, you mean like move the framing out from under the risers of the steps to be infront of the steps so I could create an angled wall and follow it down that way?
Old 07-11-2014, 08:34 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Actually you wouldn't remove the framing at all, you would just modify the wall of the closet next to the stairs. If you were to remove the trim work on the very bottom rail system you would find 2X4s cut on an angle with a 2X4 nailed flat down on top of the angle. If you had the wood removed on the bottom rail system you could pop a line up the closet wall and cut the studs to that angle, then add the top 2X4 and continue from there.
As you get on toward the top of the closet at the top of the steps you will see the wall does not extend up high enough so you would need to add 2X4s to bring the wall up to where it would need to be.
Jim
Old 07-11-2014, 10:04 AM   #10
47_47's Avatar
Rewards Points: 50
Do you have any extra flooring?
47_47 is offline   Reply With Quote
Old 07-11-2014, 07:09 PM   #11
Rewards Points: 640
flooring is getting replaced, despite looking OK in the picture, it's engineered hardwood that the top layer is delaminating off of in a bunch of locations... so that's not a concern
Stair stringer question... VitoB Carpentry 63 10-15-2013 12:13 PM
Deck stairs and rail post back blocking dwichman Building & Construction 5 05-28-2013 05:52 PM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 08:33 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 12:42 PM
Missing stair rail BlueBSH Remodeling 4 02-03-2010 05:41 PM
