How To Fix Sagging Drawers For Buildins? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 12:47 AM   #1
How to fix sagging drawers for buildins?
I noticed drawers on a buildin desk in my kitchen is sagging recently. After removing the drawers, I saw the contractor attached one of the panels using staples. Those staples cannot handle the weight so that vertical panel is patially detached. The space is tight so I cannot drill a pocket hole on the vertical panel unless I remove the whole thing. Is there other ways to fix it?
Thanks.
http://i42.tinypic.com/mm6a21.jpg
mechth is offline   Reply With Quote
Old 01-20-2014, 07:40 AM   #2
joed's Avatar
Rewards Points: 12,902
Glue a shim or wedge UNDER the panel to hold it up.
Some glue at the top before pushing it up would not hurt either.
Old 01-20-2014, 08:13 AM   #3
Rewards Points: 13,732
I might do a simple check first.
Take a level and check the bottom of that panel the drawer glide is attached to.
Reason I suggest that is to see if just gluing and lifting that piece back in place is going to effect the drawer when it's fully extended.
And to see if someone just screwed up by installing that horizontal strip to low.
Are any of the other drawers effected?
Old 01-20-2014, 09:11 AM   #4
Professional
TotalHomeworx's Avatar
It looks like it was glued and stapled in. The extra weight in the drawers has pushed it down and the rail underneath is bending from the weight as well. I would just push it back into place and add some L-brackets on either side of the divider and into the back or top bar. Use 1 1/2" L brackets and 3/4" screws.
Store your bricks somewhere else, haha
TotalHomeworx is offline   Reply With Quote
The Following User Says Thank You to TotalHomeworx For This Useful Post:
mechth (01-20-2014)
Old 01-20-2014, 10:42 AM   #5
If you do try the L brackets your going to need special screws.
particle board does not hold screws well.
http://www.rockler.com/woodworking/S...Particle-Board
mechth (01-20-2014)
Old 01-20-2014, 12:03 PM   #6
joed's Avatar
The other fix could be to leave it. It is not going to sag any further. Reset the glide to a level position.
I would shim under it quick and easy and it won't be able to sag again.
The Following User Says Thank You to joed For This Useful Post:
BigJim (01-20-2014)
Old 01-20-2014, 01:35 PM   #7
Oops! didn't realize I posted the pictures more than once.
I checked the level yesterday. Both the front and rear are sagging. There are 2 drawers. The sagging is so severe that those 2 drawers are not horizontal/vertical any more. They would even hit each other on the top adjacent corners.
For front, it's an easy fix. The rear part I believe brackets and screws would be the solution.
BTW I didn't put anything heavy in the drawers. The weight of the drawers themselves is enough to cause the sagging since the frame is not attached to the table top properly (table top is level).
Thanks everyone for your input. I love this forum.
Old 02-03-2014, 08:24 PM   #8
problem solved. I used L brackets. now the desk is solid as a rock.
thanks for everyone's input.
Please help (again):Why is my SW Pro Classic paint sagging on the second coat? Fun2Learn Painting 7 12-05-2011 10:12 AM
Fixing sagging floors in a 123 yr old house. meccadon Building & Construction 5 04-13-2011 09:58 AM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Sagging Roof nayak143 Roofing/Siding 15 06-12-2009 01:03 PM
Sagging roof? Please help! caliwildman Roofing/Siding 7 03-30-2009 11:09 AM
