Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-13-2007, 04:56 PM   #1
how to fix rotted sill plate
while replacing siding , we found the sill plate rotted from water damage. how can I replace it? its on one side of an old add on laundry room about 5 feet in length. also the corner wall stud also has rot.
carole2cd is offline   Reply With Quote
Old 03-13-2007, 05:00 PM   #2
Is thi sitting on the ground or is it on a foundation?
redline is offline   Reply With Quote
Old 03-13-2007, 05:11 PM   #3
on the concrete foundation
Old 03-13-2007, 05:21 PM   #4
One story structure or two?
Old 03-13-2007, 05:51 PM   #5
one story
Old 03-14-2007, 09:15 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Carol,
Check to see if the rotted area has allowed any sagging of the floor joists that sit on the rotted plates. If it looks ok;
What you would do is start on the inside to do this repair. First off, is the interior area on the inside of this mud sill plate finished (sheetrock attached to the plate)? If so, you would have to remove the interior materials(Sheetrock and insulation) that are attached or near to the areas to be replaced.
Inside - You would build a temporary framed wall using 2x4's with a top plate and a bottom plate. Something like this:
You would only need to build one wall that is about 2 feet longer on each end than the area it is that you are going to replace. It has to be a snug fit. You may wish to place a scrap piece of carpeting on the top plate, so as not to damage the ceiling.
This temp. wall is going to support the flooring joists and any weight that they are holding. (Those floor joists are sitting on the mud sill plate that you plan to remove and replace)
Once this is done, you can start the work on the outside. You will have to obtain a reciprocating saw (Sawz-all) if you do not have one. Using a metal cutting blade, cut the nails at the bottom ends of the studs (that are nailed into the mud sill plate and wall plate) Cut these out along the rotted area that is to be replaced.
Once this is done, use a wood blade in the reciprocating saw to cut a straight line down and cut out the rotted plates (both layers).
Remove these with a heavy hammer, small sledge, large chisel, pry bar....what ever is the best tool for the process.
Clean up the area well.
Replace these with Pressure Treated lumber. You may use KD grade stock for the wall plate and Pressure Treated stock for the mud sill. (MAKE SURE: that you try and find a dry/seasoned length of PT stock, if it is still moist, it can be swelled as much as 3/16" wider in thickness than what was originally serving as the plate. This would be a little difficult to install)
You may have to 'muscle these in. If you do run into measurement/thickness issues, you can cut a little off the studs (1/8") to fit the plates in, then shim the stud bottoms snug - and toe-nail into the plates. (You could cut the studs using a wood blade and the reciprocating saw)
Use galvanized spikes to toe-nail the new PT mud sill plate ends into the existing mud sill plates... When nailing, making sure to sink the heads even or below that plate's surface. Then install and nail the next KD plate (the replacemant for the lower wall plate)
Also: If there are any foundation anchor bolts in the area; cut a slot in the new plates on one side....(like a 'U' shape) in order to slide the replacement PT stock into the sill area. You may even be able to re-bolt these from the inside with some large washers. If you can't -don't worry about it.
Last: Remove the temp. wall. Install new insulatation and any other materials that were removed during the repair process. Close up the interior area and the exterior with new materials...
Be sure that you did find and repair the causes of the rot (to begin with) - so that this does not happen again. It may be poor drainage, roof issues, leaking window or door, removing plants, etc..etc...
Good Luck.
(FWIW: Last time we did a repair like this was also on the corner of a house. Two stories and the home's corner had dropped from the rot)
- Build Well -
More On This Topic
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
The kitchen. Long has it been the most used room in any home, the kitchen is also the one of the easiest to spruce up. While tile, flooring and appliances all entail a serious amount of time, money and energy to change, these helpful ideas will allow you... Read More »
You don't have to be a collector to need to display plates. You may inherit plates from your mother, grandmother or great-grandmother, and although you don't want to get rid of them, you know you won't ever use them. The next best thing is to hang these... Read More »
Locate wall studs using a stud finder or by measuring the space between the studs at 16 inches. Learn how to locate wall studs using the home repair tips in this free video. Read More »
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 19 04-03-2010 06:48 PM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 07:59 PM
Wood Under Door Sill is Rotted rgmetro Building & Construction 11 06-25-2007 10:49 AM
Studs to Sill Plate Tim Building & Construction 4 09-24-2006 03:23 PM
Repairing rotted top plate and joists ConsarnIt Building & Construction 4 08-14-2006 04:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
