How To Fix Gap At Bottom Of Exterior Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 09:18 AM   #1
Rewards Points: 58
Question
How to fix gap at bottom of exterior door
Hello-
I recently moved into a new home, and I found a problem with one of the exterior doors. It looks like the previous owners left the door jambs intact, and replaced the old door with a new door that doesn't quite fit properly. I have a gap between the bottom of the door and the threshold of 1.25 inches. The threshold is on concrete, and they installed one of those aluminum pieces that has a rubber seal in it. It does not seal against the door properly. Any suggestions on sealing the door? I tried to install a door sweep on the interior side of the door, but that is not stopping the cold air from coming in. The rubber on the door sweep is also starting to rip off as it is rubbing against the carpeting. Thanks for any suggestions.
propman07 is offline   Reply With Quote
Old 12-13-2011, 10:10 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Thresholds have some adjustments to them, usually (screws under the rubber piece), but not that much. You may consider shimming the threshold up to the door (which would require a little jamb modification) and rip a treated piece of lumber (a wedge, 0 to 1-1/4") to fit under the full 36", siliconed top and bottom. It makes for a little trip to remember to step over, but you get used to it.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 10:25 AM   #3
Crusty Old Dude
Big Stud's Avatar
1 1/4" is a pretty fair trip hazard. Generally you don't want more than 1/2".
If you feel safe about stepping over it, and letting anyone else who might go through the door step over this, you can build it up.
I personally would add a strip of wood to the bottom of the door and lower the bottom of the door instead of raising the threshold. It will look ugly as hell, but be safer IMHO,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 12-13-2011, 10:57 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There are several "U"-Shaped style door bottoms available with a seal attached. How about one of those? I too would extend the door before raising the threshold.
The Following User Says Thank You to Bud Cline For This Useful Post:
Big Stud (12-15-2011)
Old 12-13-2011, 12:28 PM   #5
Disabled wood vet
titanoman's Avatar
Originally Posted by Bud Cline View Post
There are seon theveral "U"-Shaped style door bottoms available with a seal attached. How about one of those? I too would extend the door before raising the threshold.
I was just trying to solve that problem the op said they already had with the sweep dragging on the carpet.
Old 12-13-2011, 12:45 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the carpet is already interferring with a sweep then apparently the threshold should be raised because my suggestion of the door-bottom wouldn't be any better I guess now that I think about it.
This assumes the threshold is detachable from the door frame assembly. Some are not.
It may take a combination of the two...threshold move/door bottom.
Old 12-13-2011, 12:48 PM   #7
Disabled wood vet
titanoman's Avatar
That's why I said the jamb may have to be modified, which may be out of their league. Also the door could be re-hung, out of plumb, the jamb also, to be perpendicular with the out of level slab. But that would be more work than its worth.
Old 12-13-2011, 02:21 PM   #8
Rewards Points: 58
Thanks for all of the replies. Here is a little more information that I probably should have included in the original post. The threshold is on a concrete slab. There is a metal piece screwed into the concrete with three screws across the 36" span at the base of the door. There is a rubber piece of material that spans the threshold that fits into groves on the metal piece to secure it after you have installed the screws. The distance between the top of the rubber piece and the bottom of the door is 1.25" all the way across the width of the door. I guess that I could cut a spacer board to fit there, and attach it to the concrete slab. I could then attach a new metal piece with rubber seal to the wood piece that has the proper height. Do the experts here think that might work?
Thanks again.
Old 12-13-2011, 02:28 PM   #9
Disabled wood vet
titanoman's Avatar
Thanks again.
As posted earlier, that's your best bet, as long as the threshold isn't integral to the jamb (the usual case) as you would need to do some light carpentry to cut the jamb/doorstop down.
Old 12-13-2011, 02:29 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
We got all of that already. That's a pretty typical installation.
Isn't that basically what was suggested in Post #2?
Old 12-13-2011, 02:57 PM   #11
I think I'm not understanding something about the geometry.
You say that the bottom of the door is 1.25 inches above the threshold. So if the threshold is .75 inches, then the bottom of the door is a full two inches above the floor.
How does a sweep on the bottom of the door rub the carpet?
If you lift the threshold 1.25 inches, then you'll have 2 inches. Sounds like I'd be tripping over that all the time. I'm sure any visitors would.
Any chance you can post a photo?
pyper is offline   Reply With Quote
Old 12-14-2011, 09:05 AM   #12
Rewards Points: 58
I will see if I can get a photo, and post it later. It looks like the suggestions in post #2 will be the way to go for the repair. Thanks to all for the input and suggestions.
Old 12-14-2011, 07:36 PM   #13
Crusty Old Dude
Big Stud's Avatar
I have seen situations where the floor is not level and the door had to be cut off to allow it to open fully.
If that is the case and you have no choice than to raise the threshold then I suppose you must do just that.
I would look at what is wrong with the floor and address that issue if it were mine and this was the case, so my door could be more user friendly,
Rotten bottom plate & studs. (Photos) JustADoc Building & Construction 24 08-10-2011 10:01 PM
Bottom of drywall jessica042785 Drywall & Plaster 3 02-15-2010 11:11 AM
Framing Door at Bottom of Stairs kothep Building & Construction 16 08-10-2009 03:03 PM
bathtub bottom squeaks. What's wrong? hohadcr Carpentry 2 07-27-2009 08:05 PM
Boring holes in a load-bearing bottom plate benjamincall Building & Construction 22 01-21-2009 10:05 PM
