How To Finish Basement Stairwell Concrete Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 02:34 PM   #1
how to finish basement stairwell concrete wall
Trying to figure out best way to finish this concrete wall along basement stairs. It is poured conrete and I believe stringer is 1.5" so I need to install something that will not be too thick. Should I tapcon some PT 1x3" and apply 1/2" greenboard and put foam insulation in between these furring strips? Or any better suggestions? Will attach pictures later. Thanks..
legende is offline   Reply With Quote
Old 08-25-2011, 04:27 AM   #2
m1951mm's Avatar
I am not sure why you would want to use green board. Would a vapor barrior be a better solution attached to your furring strips? Do you have problems with moisture in your location? Could 3/8's inch drywall be used to give you a better reveil for your trim? Hope some of the others chime in here!!
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 08-26-2011, 12:42 PM   #3
buckybadger's Avatar
Rewards Points: 85
If I was presented with this I'd probably do exactly what you suggested. Since it's below grade I'd stick with some kind of basement board for sure.
buckybadger is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 01:59 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
