#1 |
How to drill into metal window header?
I think my window header is metal and it seems to go up about 4-5 inches from my window. I can't drill into it. I'm trying to hang curtains. I have tried wooden and metal drill bits (it might be wooden but i don't think so). What should i do? I got about an inch into it and then i can't get any further.
On second thought i might be having a problem drilling into studs. My drill is a dewalt DW997 18v thanks. |
#2 |
Remodeling Contractor
A good metal bit will drill into it. Use a cobalt bit, not a wood bit, not a brad point bit, not a cheap bit from Sears or Home Depot and such. Drill first with a 1/8" bit or smaller, lubricate with a drop of cutting oil. Then drill the 3/16" you need for your screws.
#3 |
Old School
There's a good chance that you successively drilled through the 3/4 " of window bucking ( an easy-to-drill band of wood around the top and sides of your window) and are now hitting something harder. If it is a block construction home, that would now be concrete block. But some construction pine can seem as hard as cement.
#4 |
are you sure your not plugging up the twists on your bit?? Pull out,clean , and try again!!! Just in case IF its concrete switch to a mason bit, OR shorter screws
#5 |
Whatamess
Sounds like you are way past the metal 1/4" - 3/8" thick and now need a hammer drill for concrete. Just a guess.
I have in the past drilled and tapped the metal so I could use machine screws.
I may go home hungry, but not tired and hungry. |
| Display Modes | |
| Lock for metal casement window? | Casey421 | General Discussion | 1 | 09-16-2008 06:47 PM |
| Wire size for 300watt trans, 3 way 100ft | Al the Diy guy | Electrical | 16 | 03-22-2008 09:46 PM |
| Non-load bearing window header in exterior wall | timelyirony | Building & Construction | 3 | 12-08-2007 05:15 PM |
| Insulating metal window frames | SagittarianLady | General Discussion | 6 | 12-08-2007 10:36 AM |
| Condensation on Metal Window Frames: Should I Caulk? | xquercus | General Discussion | 6 | 06-29-2007 10:24 AM |
