-   -   How to drill into metal window header? (http://www.diychatroom.com/f14/how-drill-into-metal-window-header-36997/)
BrandonDL 01-27-2009 07:25 PM
I think my window header is metal and it seems to go up about 4-5 inches from my window. I can't drill into it. I'm trying to hang curtains. I have tried wooden and metal drill bits (it might be wooden but i don't think so). What should i do? I got about an inch into it and then i can't get any further.
On second thought i might be having a problem drilling into studs.
My drill is a dewalt DW997 18v
thanks.
Bob Mariani 01-28-2009 06:50 PM
A good metal bit will drill into it. Use a cobalt bit, not a wood bit, not a brad point bit, not a cheap bit from Sears or Home Depot and such. Drill first with a 1/8" bit or smaller, lubricate with a drop of cutting oil. Then drill the 3/16" you need for your screws.
Willie T 01-28-2009 08:01 PM
There's a good chance that you successively drilled through the 3/4 " of window bucking ( an easy-to-drill band of wood around the top and sides of your window) and are now hitting something harder. If it is a block construction home, that would now be concrete block. But some construction pine can seem as hard as cement.
4just1don 01-28-2009 08:27 PM
are you sure your not plugging up the twists on your bit?? Pull out,clean , and try again!!! Just in case IF its concrete switch to a mason bit, OR shorter screws
TazinCR 01-29-2009 05:01 AM
Sounds like you are way past the metal 1/4" - 3/8" thick and now need a hammer drill for concrete. Just a guess.
I have in the past drilled and tapped the metal so I could use machine screws.
