Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-27-2010, 07:24 PM   #1
How do you miter a corner that is 144 degrees?
I am driving my self nuts trying to figure out how to miter a corner that is 144 degrees. Since my saw does not go to the 72 degrees needed what do I need to do? Thank you in advance for any tips.
beewill is offline   Reply With Quote
Old 10-27-2010, 08:17 PM   #2
STAFF
BigJim's Avatar
Cut you a long 27° wedge and set your saw on a 45° lay your trim against the long angle and there you go. Be sure to hold the board very tight and be safe.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 10-27-2010, 08:19 PM   #3
Without knowing the tools available to you, my first inclination would be to fabricate an 18 degree wedge and place it against the fence of a miter saw. Set the saw at 90 degrees, place the wedge between the fence and workpiece, and cut.
oberkc is offline   Reply With Quote
Old 10-27-2010, 08:59 PM   #4
STAFF
BigJim's Avatar
Yep, that will work also.
Jim
Old 10-28-2010, 01:40 PM   #5
uva uvam videndo variafit
WirelessG's Avatar
Strike a line and use your circular saw.
WirelessG is offline   Reply With Quote
Old 12-08-2010, 04:19 AM   #6
BestMiterSawRatings.com
And make sure you have plenty of money to spend when the cuts you make are "just a bit off" LOL
akilez is offline   Reply With Quote
Old 12-08-2010, 01:16 PM   #7
WirelessG's Avatar
If you know what you are doing your cuts don't end up "just a bit off".
Old 12-09-2010, 01:22 AM   #8
Wow, I never meant that as an attack. So my suggestion is if you are that confident in your cutting, why let a simple caveat like mine throw you into such a tizzy?
My apologies once again if I offended some sensibilities I was otherwise unaware of.
Old 12-09-2010, 02:01 PM   #9
WirelessG's Avatar
You didn't throw me into a tizzy, nor did you offend my sensibilities. You simply made an ignorant statement and you continued with your last statement.
Old 12-09-2010, 02:33 PM   #10
You are absolutly right. Thanks for pointing it out.
Old 12-10-2010, 06:06 AM   #11
I would like to chime in here. I'm not Norm Abrams but I would like to see a perfect cut done with a circular saw that would be better than a chop saw.
hrjrkr is offline   Reply With Quote
Old 12-10-2010, 11:46 AM   #12
hold piece at 90 to rail set saw to 36 or it may be 8 dont have saw in front of me
The older I get the better I was
Old 12-10-2010, 12:06 PM   #13
A Little Of Everything
I know I've never done it. I just built a hearth, mantel, bookshelves and installed all the trim in a new room. It would have been virtually impossible to do without my 12" compound miter slide DeWalt.
Of course, there are a LOT of people who are a lot better than I am.
DrHicks is offline   Reply With Quote
Old 12-10-2010, 12:09 PM   #14
I'm probably missing something here, so please pardon my probable error and general ignorance...
When you're talking about a 144 degree angle, you're speaking of one like this sketch, right?
Why couldn't you set your miter saw at 54 degrees and back-cut it?
Old 12-11-2010, 01:09 AM   #15
Cabinet maker
Augie Dog's Avatar
Pictures are worth a thousand words.
This angle measures 53 degs when measured with a Swanson Speed Square. That could be considered 127 degs but not normally the way it is called in the carpentry world.
Here is the trick;
Take the 53 and subtract it from 90. That leaves 37. Divide that by 2 and you have the magic number for the fixture angle of 18 1/2 degs.
Cut a fence block at your 18 1/2 and move the saw back to 90. Clamp it down and nibble a little of the long point off. That will be handy for a couple things, one is it gives you the exact location of the cut line to line up a mark on your work piece if you are cutting it to finished length with this cut.
Find a way to hold your piece down safely against the fence and cut.
You may need to make a slight adjustment to get a great fit. But that is one way to get it done.
Augie Dog is offline   Reply With Quote
The Following User Says Thank You to Augie Dog For This Useful Post:
canadaclub (12-11-2010)
How to cut bullnose corner crown molding using compound miter saw darryl0214 Building & Construction 1 03-15-2010 06:58 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
math for checking for 90 degrees in a corner coderedcraze Carpentry 17 12-02-2006 01:40 AM
