How Do You Make "V" Seams In Car Siding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 04:03 PM   #1
Five years ago when we built our home, the carpenter used a technique that created a "V" channel for every seam in the car siding on our ceiling, rather than simply butting or trying to hide the seams. I should have paid more attention because now I'd like to duplicate that in my basement. Anyone able to help me out?
Phil in Wisconsin is offline   Reply With Quote
Old 12-26-2008, 05:50 PM   #2
Registered User
Termite's Avatar
Actual car siding has the chamfered "V" seams....It comes that way. Your carpenter must have been using tongue and groove boards with no pattern and running the pattern on them.
However, to answer your question, the groove can be cut in the wood using a router and a diamond-shaped bit. The router would need a straight edge of some sort or a fence.
Old 12-26-2008, 05:51 PM   #3
Registered User
Termite's Avatar
Here's the bit...
Tags
car siding , techniques
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
Is this Asbestos Siding or Cement Siding? Pictures inside!!!! twilightcall Remodeling 12 02-01-2008 08:27 PM
Siding & cold air drake9 Building & Construction 8 03-08-2007 10:37 AM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 08:43 PM
