How Do You Hang Pvc? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 03:33 PM   #1
How do you hang pvc?
Question.. 4" Pvc Exterior Trim
I have trim nail guns up to framing up to siding nail gun.
Would it be my best option to hand nail them and leave the nails visible or can i use a trim nail gun and use a pvc epoxy or something to fill them?
DukeLewis87 is offline   Reply With Quote
Old 06-07-2013, 03:44 PM   #2
Rewards Points: 12,812
Trim nails are to small a gauge and will rust.
Predrill the holes and use double dipped finish nails. Use a nail set to set them just below the surface and use something like Alex 230 caulking to fill the nail holes.
Use a stiff damp sponge to wipe off the excess. Do not leave any on the surface of the trim.
Old 06-07-2013, 05:08 PM   #3
Roofmaster
Rewards Points: 2,172
How is the water going to get to the trim nails? I just installed some PVC trim on an exterior with my trim nailer, and used alex sealant on the nails so I guess Ill see. The trim is sealed on both sides with sealant too, but who knows, you may be right.
The Following User Says Thank You to jagans For This Useful Post:
MTN REMODEL LLC (06-07-2013)
Old 06-07-2013, 05:38 PM   #4
Remodeler
Rewards Points: 296
GRK trim head screws is all I have ever used. Your trim will stay put instead of loosening up and pulling away over time. A little slower than using a nailer but no pre-drilling required, they run in easily with a cordless drill or impact driver. Best of all you will never have to mess with the trim again.
PVC expands and contracts more than other materials, it needs to be fastened well. A finish nailer is just not going to do that. Nails that will rust are never a good idea on siding or trim, even when not exposed.
The screw heads can be driven just below the surface and caulked or there are other options that drive the screw and drill a plug hole, then a matching plug can be driven making the screw all but invisible. I have never used these but it looks interesting.
Cortex hidden fastener
iamrfixit is offline   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
djlandkpl (06-07-2013)
Old 06-07-2013, 06:03 PM   #5
Trim screws work fine but leave a raised spot and have a larger head then a finish nail.
The double dipped finish nails are so rough I've never had one back out.
Old 06-07-2013, 07:07 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
ive installed thousands of feet of pvc trim, weve had issues with lighter gauge galvonized nails.. not only do 16 gauge pins not have enough hold but the galvy`s do rust and bleed..
the best methods we have found is 15 gauge stainless steel no less than 2" long, or cortex screws.. the 15 gauge nails have a head which gives much more holding power and hte heavier shank resists seasonal movement. cortex screws hold even better however it takes quite a bit longer to fully fasten a piece.
heres just a few houses that ive worked on.. the cedar shingled ones recieved azec fascia and soffit details.. the other ones were azec trim around the windows and corner posts
How do you hang pvc?-azec6.jpg   How do you hang pvc?-photo1007.jpg   How do you hang pvc?-photo1056.jpg   How do you hang pvc?-azec1.jpg
woodworkbykirk is offline   Reply With Quote
Old 06-07-2013, 07:30 PM   #7
kwikfishron's Avatar
Rewards Points: 86
Like the lattice rain screen Kirk.
kwikfishron is online now   Reply With Quote
Old 06-07-2013, 09:28 PM   #8
its sorta a step back.. we used to use homeslicker however the local building officials no longer accept it.. reason being too many guys are hand nailing cedar shingles which compresses it when the nail draws in.. gun nailing with a coil nailer or stapler doesnt draw the shingle against the house. theres a new plastic grid system avaialbe now but it costs about $1.45 /sq ft
Old 06-08-2013, 04:55 PM   #9
KemoSabe
loneframer's Avatar
Azek recommends a full head nail with a blunt point for fastening....however, I've been using 16 gauge stainless steel gun nails for years and haven't had a piece come off yet. 18 gauge SS for trim pieces. For fascias, I like to pre-drill and use a SS siding nail or trim head SS screws to support gutter.
The only time I fill nails in PVC is if it's an entryway area. Anything you use will collect dirt and show as bad or worse than the small hole over time.
How do you hang pvc?-006.jpg   How do you hang pvc?-018-1.jpg   How do you hang pvc?-044-1.jpg   How do you hang pvc?-041-1.jpg   How do you hang pvc?-046-1.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Please help me figure out how to hang heavy bag in basement. llO0DQLE Building & Construction 4 04-05-2013 11:14 AM
How to hang stuff from an engineered joist? Toller Building & Construction 4 01-22-2013 06:09 PM
roof over hang bpurvis Building & Construction 3 12-14-2010 05:32 PM
1x6 16' T&G Ceiling (Hang and Stain) themayor Building & Construction 5 03-07-2009 10:59 PM
Phone will not hang up--help! rudy6380 Electrical 2 06-29-2008 09:25 PM
