How Do You Guys Hold These Tiny Screws? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 05:32 PM   #1
How do you guys hold these tiny screws?
I build a lot of cabinets. Some want the cheaper self closing hinges instead of the euro ones. I have a heck of a time getting those tiny screws started. (note; I predrill the holes, since most of my work is hardwood.) I have huge hands! I work alone. So here I am holding the door in place with one hand trying to get these little suckers started. I have tried using a piece of tape, works but really slows things up. Can't find a magnetic screwdriver strong enough. They only work about 50% of the time. A touch of plumber's putty works, but is hard to clean up. Anyone have an idea that really works?
Thanks,
Oldchipper is offline   Reply With Quote
Old 05-30-2009, 06:26 PM   #2
Old School
Willie T's Avatar
If they are steel screws, the 3" DeWalt magnetic tip holders for your screwgun always worked well for me. Never tried a magnetic screw driver.
If brass screws, the more expensive tips seem to do a better job of holding screws.
Franšois Duc de La Rochefoucauld
Willie T
Old 05-30-2009, 06:53 PM   #3
Can you use square drive screws?
jerryh3 is offline   Reply With Quote
Old 05-30-2009, 07:30 PM   #4
Magnetize your own screwdrivers.
hayewe farm is offline   Reply With Quote
Old 05-30-2009, 07:38 PM   #5
Registered User
Rewards Points: 5,212
Or: http://www.sears.com/shc/s/p_10153_1...rd=screwdriver
Put cursor on picture of tip. Be safe, G
Old 05-30-2009, 08:36 PM   #6
thanks
thanks for the fast replys!!!
GBAR, I'm off to Sears, first thing in the morning. That's just what I need. Funny part is, I had one of those 50 years ago, but I had forget about them. Old age ain't what it is made out to be!
thanks again
Old 05-30-2009, 09:11 PM   #7
the Musigician
DangerMouse's Avatar
i have one of those, but i opt for a hard drive magnet stuck close to the end of the driver.
it holds more screws and holds the one you're screwing TIGHT to the driver tip.
good ol' 1,000 uses hdd magnets.... Po)
DM
Old 05-30-2009, 09:51 PM   #8
Registered User
Termite's Avatar
I have the greenlee version of that screwdriver, and they do work pretty well. I use mine for electrical work...Getting that little grounding screw started in the back of a box can be a challenge for big hands.
Old 05-31-2009, 08:28 AM   #9
I suspect the lack of magnetism is also due to differnt metal content in todays cheaper "bulk" screws ... possibly from offshore or the coating on them. If you test a few suppliers you might find a better product as well or remagnetise your driver as suggested above
Chemist1961 is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
Trying to get screws to hold in soft wood fw2007 Carpentry 1 08-22-2007 10:20 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
