How Do You Fix Nails Holes In Paintable Base And Casing "after" They Are Painted? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 05:19 PM   #1
How do you fix nails holes in paintable base and casing "after" they are painted?
I have done a lot of reading on the process of preping modlings/casings for painting. I guess I am lucky because not all of my molding and casings have already been painted and I can make sure they are prepaired correctly. In many cases however the paint job has already been painted. This really looks bad and the nail holes are very visable. They either used nothing and just painted over the holes or use cauking.
Does anyone have any ideas how I can repair this or is it best to just replace the affected areas?
thanks,
Jim
Darkwave Master is offline   Reply With Quote
Old 12-07-2010, 06:02 PM   #2
kwikfishron's Avatar
Rewards Points: 414
thanks,
Jim
Fill the holes and another coat of paint.
kwikfishron is online now   Reply With Quote
Old 12-07-2010, 09:59 PM   #3
A Little Of Everything
Rewards Points: 1,364
Yep. You can use drywall mud - if you have some on hand. Also, Durham's Wood Putty, or maybe even spackling compound.
DrHicks is offline   Reply With Quote
Old 12-08-2010, 07:17 AM   #4
40+yrs Paint Trades
Painters putty or glazing compound.
hoz49 is offline   Reply With Quote
Old 12-08-2010, 07:40 AM   #5
Rewards Points: 414
I like something I can sand (today).
Usually always have a partial bag of hot mud around, works great.
Old 12-10-2010, 05:40 AM   #6
DAP lightweight Spackle does a great job for me. Very easy to use,dries quick,sandable(and easily so). It'll make the holes invisible. By the way,Drywall mud is NOT the way to go.
white29 is offline   Reply With Quote
Old 12-10-2010, 07:36 AM   #7
Out of curiosity, why do you say that?
My experience has been the exact opposite. Not so much a love affair with drywall mud (as if that's actually possible), but a disgust at the worthlessness of lightweight Spackle.
Thanks!
Old 12-11-2010, 03:46 PM   #8
Thanks!
I use the lightweight DAP too. DW mud may be too solvent in that application as opposed to mudded wall joints
mrgins is offline   Reply With Quote
Old 12-16-2010, 09:49 PM   #9
thanks,
Jim
You can buy nail hole filling crayons at the building center. They have a full range of colors.
You just run the crayon back and forth over the hole and the wax is deposited in the hole.
Then, any excess is wiped off with mineral spirits.
Old 12-17-2010, 03:43 PM   #10
Can you paint over those?
Old 12-17-2010, 07:21 PM   #11
In my case, I filled the holes in a natural, eurathane finished oak baseboard. I finished the wood and then filled the holes with suitable colored crayon.
Looking back, that was almost 10 years ago and there has been no problem.
I call them crayons, but they aren't the same as a childs crayon. Given time it seems to harden.
They are inexpensive, so I would suggest that you would buy one and try it out.
Old 12-17-2010, 08:14 PM   #12
40+yrs Paint Trades
The "crayons" are for varnished wood not painted. The correct filling is glazing putty or "Painters" putty. It's linseed oil and whiting and has been used to fill nail holes for centuries.
It stays pliable, doesn't dry out like muds or spackle, doesn't flash when you paint it, putty doesn't shrink, and it holds in the hole better than either of them.
You don't have to sand putty. Just run the ball over the hole until it's slightly over full and wipe off excess with your finger or flexible putty knife.
Painters also color putty on the job to match varnished woods and use like the crayons mentioned above.
When running trim we always carry a piece of putty stuck on the edge of the paint pot to fill holes.
1000sq ft of teak, do i remove base trim, saw door casing ?? PendletonCowboy Flooring 4 10-20-2009 04:04 AM
