How Do You Build A Door Jamb? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 05:37 PM   #1
how do you Build a door jamb?
Okay
I bought the stuff I need to build this door jamb can anyone tell me how to put it together?
I have a doorless doorway. framed at 80-3/4" X 49"
thIS WILL BE a doorway with no doors.
I went to a place that specializes in doors and bought the 4-9/16 oak ven jam. and the casing.
questions.
1. whats this type of doorway called?(ive been trying too google it)
2. do i nail the 4-9/16 oak ven jam in first? or do i measure cut and nail together then install it?
3. I would assume the casing goes last and is pretty straight forward.
Thanks to all who will help me.
luweee is offline   Reply With Quote
Old 06-12-2009, 05:53 PM   #2
the Musigician
DangerMouse's Avatar
so, you're just building a casement to 'wrap' a door opening for no door. got a picture? easier for us to see what you have to work with.
i'd put the 4-9/16 on first, then add casing myself. how do you plan to finish off the top? i 'm finishing my doors and window casements like this, if it helps.
http://www.diychatroom.com/f50/verti...-blinds-45533/
Po)
DM
Old 06-12-2009, 06:01 PM   #3
Man that looks awewsome!!!!!!!!!!!!! Great job.
NO pics for me. Im doing something very similar.
I am finishing my basement.
I have a 2X4 framed doorway 80-3/4" tall by 49" wide.
just want to "wrap" the doorway as you said I guess.
Thanks dangermouse.
Can you guide me through this?
Old 06-12-2009, 06:10 PM   #4
the Musigician
i'm sure lots of us here can pitch in. Po) what do you have for the front and back casing/moulding... (sides and top?)
mdf? what are the materials here?
DM
Old 06-12-2009, 06:23 PM   #5
i have oak casing to match the jam. smaller bout 2.5 inches approx.?
the jams 3 pieces 6ft 8inches each. need to cut these to fit.
all have a notch cut out ("L" shaped).
i am assuming thats for the top piece to lay across?
Old 06-12-2009, 06:28 PM   #6
the Musigician
i'm assuming you're assuming correctly...
DM
Old 06-12-2009, 06:28 PM   #7
the Musigician
what are you using to fasten it? finishing nails?
DM
Old 06-12-2009, 06:32 PM   #8
do you take the legs of the jam all the way to the floor?
or raise slightly? if so, how much?
Old 06-12-2009, 06:47 PM   #9
the Musigician
what is the floor now, or what is it going to be? if you have the floor you want, go right to it flush.
DM
Old 06-13-2009, 08:32 AM   #10
Old School
Willie T's Avatar
It is too easy to get everything out of line if you attempt to put the pieces up one-by-one.
Build the frame like this first, and install it as a unit. Then later, fit it with casing.
The example here is 1-1/2" stock.
how do you Build a door jamb?-door-frame.jpg   how do you Build a door jamb?-door-frame-2.jpg
Willie T
Old 06-13-2009, 09:45 AM   #11
the Musigician
well sure Willie, you can cut it to size and piece it together to be sure it's perfect before mounting it, but only if you want to do it the RIGHT way....
DM
Old 06-13-2009, 09:51 AM   #12
Old School
Willie T's Avatar
DM
I do apologize. I fully understand the benefits of doing a job three times to get it nearly right. It's good practice, and you become very familiar with all the details. But I'm lazy, and really only want to do things once.
Willie T
Old 06-13-2009, 11:14 AM   #13
the Musigician
hehehehehehe
DM
Old 06-13-2009, 12:17 PM   #14
I usually just put the top piece up 1st, then put the sides on
I make sure when I frame it out that its level
Then put the casing on each side
As long as everything is square its fairly easy
Of course this house & the last are not new
And the last house the only thing that was square/level was my square
Old 06-15-2009, 10:56 AM   #15
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
The diagram that is shown forgoe the rabbit (groove) in the head (top) piece and most of the prefabed kits they sell have the legs with a recess the thickness of the jambs. This is simple as you see in the diagram turn those side jambs 180 so the flange is on the outside (you don't have to rabbit the top this way as in the diagram). Then glue and pin the top jamb and side jambs together. I do not intend this message to say that process is wrong so please don't yell at me LOL It will work either way I just think we can simplify it for the OP.
Then insert the built wrap in the opening, shim and secure just like you are setting a door. If you have any questions on how the jamb will look, go peek at the doors that are already installed in your home and you will more than likely see the configuration on how to pin this wrap together.
Then case it out and voila you are done!
Good luck and be safe!
Paragon is offline   Reply With Quote
can you build your own drywall lift?....done! DangerMouse Drywall & Plaster 33 04-14-2016 09:04 PM
Would like to build kitchen cabinets handyhall Carpentry 8 06-28-2009 11:15 AM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 07:13 PM
Fire pit build over existing concrete deck - am I headed for trouble? mitchcos Building & Construction 10 04-15-2009 07:26 AM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
