How Do I Replace My Fascia Boards? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 10:55 PM   #1
How do I replace my fascia boards?
What is the best way to replace the fascia boards on my house? They are nailed to the rafter ends which really does'nt seem to be a problem but there also nailed from the top of the roof, there is two layers
of shingles on the roof, Any ideas?
Doug
schermd is offline   Reply With Quote
Old 03-22-2011, 10:58 PM   #2
Rewards Points: 5,336
Take a reciprocating saw and cut the nails coming through the sheathing into the fascia.
Ron
Old 03-23-2011, 07:51 AM   #3
Rewards Points: 2,240
As "ron6519" says -
Reciprocating saw (Saw-Z-All), with a long blade - 10" - 14".
"Nail-Embedded Wood" or "Bi-metallic" blade.
If the roof sheathing is tight to the top of the fascia - drive the end of a
"pry-bar" between the sheathing and the fascia - to create a space - so
that you can get the blade in, with minimal binding.
rossfingal
rossfingal is offline   Reply With Quote
Old 03-23-2011, 09:05 AM   #4
Ok, but what about installing the new pieces, do I need to be able to peel the roof back to nail thru the roof into the new pieces? I would hope not, it looks kinda tough.
Thanks for your replies, Doug
Old 03-23-2011, 09:27 AM   #5
I've never nailed fascia down through the roof sheathing.
I've never even seen it done.
Ron
Old 03-23-2011, 09:31 AM   #6
If your rafters are 16 inches on center, and are in good condition - you
probably don't need to nail through the roof into the top edge of the fascia.
If they're wider apart (2 feet O/C) or in questionable condition -
consider adding blocking between the rafter tails, flush with the outside edge
of the rafter tails - provides good nailing.
You may not have to do this for every rafter bay.
I don't know what type of material you're going to use for the new fascia
(cedar, pine, composite, etc.).
You should at least "Prime" all sides of the fascia before you install it -
2 coats would be nice! (Or pre-stain the pieces)
After we make our cuts to fit the pieces together (before we install them)
we also Prime the cut ends.
It's a fun job, isn't it!?
rossfingal
Old 03-23-2011, 09:34 AM   #7
does the roof have metal drip edge? thats a whole different animal. also when clipping nails behind old try to watch for shims that may fall out
The older I get the better I was
Old 03-23-2011, 09:37 AM   #8
ron6519
Yes, have seen it, all too often.
Those "darn" roofers/framers do some strange, "darn" things!
RF
Old 03-23-2011, 03:04 PM   #9
Tizzer's Avatar
Rewards Points: 470
Before you go whacking all the old boards off, look how the old ones were. You want the new boards located just down from the top rafter edge so the shingles don't stick up.
The longer the boards, the better. Less joints. And try to keep them run to a string line (or a chalk line).
I can't think of one reason why a roofer would be nailing shingles that close to the edge.
Tizzer is offline   Reply With Quote
Old 03-23-2011, 03:23 PM   #10
Household Handyman
Rewards Points: 1,408
Come on down to S.W. Georgia Ron, I'll show you that 90+% of the homes built here get nails through the roof decking and the drip edge. This makes for an interesting day when replacing fascia. I pull all nails driven into the rafter edges, use a pry bar to start getting the board loose at one end, and keep pulling until the board will pull loose. Then I go back and cut all the nails coming through from the decking/drip edge. The new fascia boards go up nailed to the rafter ends only, and behind the drip edge.
Old 03-23-2011, 07:37 PM   #11
The fasica boards I am wanting to replace are running the same way as the rafters so there are no rafter ends to nail to, there are 2X4's about every three feet laying flat.
Doug
Old 03-23-2011, 08:02 PM   #12
Doug
Methodology is the same.
Ron
Old 03-23-2011, 08:17 PM   #13
kwikfishron's Avatar
Rewards Points: 1,024
Ron
You have through the barge board.
kwikfishron is online now   Reply With Quote
Old 03-23-2011, 09:43 PM   #14
"kwikfishron"
Interesting! - haven't heard the term "Barge Board" in a while.
"Gables", "Rake Boards", etc.- "Barge Board" ?!?
Didn't hear that term until I was out in the S. West - West Coast areas
(years ago - I'm a Midwestern boy)
RF
Old 03-23-2011, 10:29 PM   #15
Yep there barge boards, hay I just learned something new, thanks for the correction, ah now I need to figure out how I am going to replace the barge boards.
I need to figure out how to post pictures on here so you guys can give me some ideas.
Thanks, Doug
Doug
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Water/Ice on fascia leaking into sofit and house da_man Roofing/Siding 1 02-07-2011 03:22 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Plastic fascia and soffit panel attaching to it. 4just1don General DIY Discussions 1 07-22-2009 09:26 PM
Are fascia boards rough carpentry? Paul58 Building & Construction 10 04-19-2006 10:18 PM
