How Do I Repair My Window Frame - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-19-2006, 11:19 AM   #16
renovations
I'm pretty sure you can't fix that outside a shop, also it looks like the next vertical to the right has suffered some damge too. It's gotta come out of there to be fixed properly and so you can see what other damage the water has caused.
Or... do a better job with more filling and sanding, and this time paint the whole thing not just the patch.
Bonus is offline   Reply With Quote
Old 11-26-2006, 04:44 PM   #17
Originally Posted by sherlock View Post
Looks to me like it is separate boards - 4 vertical and 2 horizontals. That's why I figured I could just patch it in the first place.
Replace or repair?
redline is offline   Reply With Quote
Old 11-26-2006, 07:53 PM   #18
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by redline View Post
Replace or repair?
...Um...., Redline, Do you realize that you are responding to a post that originated in JUNE of this year?...
... and the last post on it was OVER 3 months ago???
- Build Well -
Old 12-20-2006, 09:54 AM   #19
I work for a window company and when we come across this we will have someone take the whole thing out to see the extent of the rot. Usually in cases of rot the way to go is replace to whole window or you are going to have problems down the road. Even with the way this was installed, it looks like the weep system may be clogged and eventually you would have seal failure in your glass anyway.
dyad8 is offline   Reply With Quote
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
How to repair deterioration on inside of window frame? darsunt Carpentry 2 08-13-2007 04:40 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
