How Do I Repair An Interior Door That Will Not Stay Open? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 08:18 AM   #1
How do I repair an interior door that will not stay open?
The problem is, I try to open the door(s) all the way, but they try to swing back slowly to close. I need a simple solution to fix the problem.
Thanks for you help.
___________________
http://www.getridofbedbugsathome.com...d-of-bed-bugs/
Lindavald is offline   Reply With Quote
Old 06-04-2012, 08:23 AM   #2
Rewards Points: 12,818
Remove a hinge pin and set it between 2, 2 X 4's and give it a tap with a hammer to just slightly bend it.
It's that or remove the door and rehang it plumb.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
jaydevries (06-05-2012), PaliBob (06-05-2012), Willie T (06-08-2012)
Old 06-04-2012, 08:35 AM   #3
Too Short? Cut it Again!
Doorstop?
Old 06-04-2012, 10:48 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
Something for fixing the unclosed door from closing/opening on its own, as sdsester mentioned a door stop.There is a magnetic type door stop where part of it is mounted to the baseboard molding along the wall at floor level behind the door and the other part mounted to the door so that when the door was opened toward the wall the two pieces met. This was a heavy solid core door leading up to an unfinished bonus room and the stop held the door firmly in place.
the door stop part that attaches to the baseboard sticks out from the baseboard a few inches to allow distance for the door knob, sometimes this is a problem because it can be a toe stumper, ouch.
hand drive is offline   Reply With Quote
Old 06-05-2012, 08:47 AM   #5
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
There are a couple of things that might cause this.
First check......I am assuming the hinges are not a "Rising Butt Hinge"
These are intended to raise the door to lift it over carpet etc. As this action is like a spiral shoulder on the hinge, gravity will want to close the door after opening. Solution would be to replace the hinges with regular butt hinges.
Second......The door frame is out of plumb. If you have a removable stop, you can reposition the hinge so that the door is plumb. The stops can be reinstalled to fit the new door position. Leave the thickness of a credit card between the door and the stop for clearance.
If the stops are part of the jamb, you can still move the hinge out until the door is plumb, then an additional overlay stop should be installed to cover the gap.
If all the above fails, remove the door frame and reinstall correctly making sure that the frames are plumb and level.
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 06-05-2012, 03:16 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by joecaption View Post
Remove a hinge pin and set it between 2, 2 X 4's and give it a tap with a hammer to just slightly bend it...................
I'm with Joe except I just take the hinge pin outside and prop it at an angle between the curb and the gutter, then give it a whack.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-08-2012, 07:06 PM   #7
Can’t believe I'm reading this....
OP
DON'T WHACK or bend HING pin, any strong binding of hinges/pins cause the pin to walk out and or causes stress on the hinge screws and you loose that. You’ll create a "Sprung hinge" effect and door may not shut/hit slam strip at all, and you will be buying more hinges.
That credit card measurement. NOT thick enough. Even in the Hollow metal door industries a metal door can expand and contract to close that credit card gap. Wood doors are worse swelling, not to mention too tight and the latch hits the strike plate hard, then more trouble.
Try changes swapping the hinge locations. Existing top hinge to middle and middle to bottom and bottom to top. Just by removing them and reinstalling them can cause enough different minuet alignment to get natural pin friction to stop your problem.
21boat is offline   Reply With Quote
Old 06-08-2012, 10:26 PM   #8
I'm with with the crew that advises a small bend in the hinge pin. It will only take a very small bend to correct a door that closes slowly. You will not cause the hinge pin to walk or the screws to loosen. I will come fix the door myself if those things happen.
HartKyle83 is offline   Reply With Quote
Old 06-08-2012, 11:15 PM   #9
Old School
Willie T's Avatar
I've done at least thirty or forty doors this way over the years. It's a gentle bend, it hurts nothing.
Willie T
Old 06-09-2012, 09:14 AM   #10
Bill Kearney
Rewards Points: 1,174
Like this one: http://www.amazon.com/Get-Organized-.../dp/B000A7OOZ0
Went with one like that on one of my doors. It's a metal, all glass door in metal frame that used to be for an external entryway, but now has a 3-season glass room (installed by previous owners). Fixing the metal frame door wasn't really an option.
A nice feature is the part on the door is a socket with a spring inside the catch for the ball. This allows the door to be swung open harder against the catch without causing damage. I've got the magnetic post installed horizontally from the baseboard behind the door. Works great.
Solving the problem 'the right way' would require finding out where the door frame is out of level and fixing that. But this can be a lot of work as you can't just move one portion of the frame without there being potential issues on the other sides. As in, the hinge side of out of level, so you pop off the moldings on that side and re-shim it to get it level. This means the door is now likely to be a little farther over on the other side and might not have enough room to close properly.
So using a magnetic stop is sometimes a lot less trouble.
wkearney99 is offline   Reply With Quote
Old 06-09-2012, 10:55 AM   #11
Rewards Points: 272
I am with Willie Joe and Pali on this one. A slight tap with a hammer on the pin ( I do it on concrete) and there you have it. It is not as if the door is slamming shut, so in all my years of experience THIS is the most reasonable solution.
fixrite is offline   Reply With Quote
Old 06-09-2012, 11:33 AM   #12
Bill Kearney
Well, yeah, if all you're trying to do is make the door harder to close. Bending the pin will do that, it'll make that hinge stiffer to close and that might help keep the door from swinging closed as easily. Depends on how fast the door is swinging shut. If it's just a gradual creep, then a tighter hinge with a bent pin might be enough. That is until the hinge wears and the problem returns, or starts squeaking enough to drive you crazy.
Old 06-09-2012, 01:18 PM   #13
Rewards Points: 272
Well considering the doors that I have applied this to have been working perfectly for over 27 years I would say it is a no brainer that it is not only affective but lasts without any ill affects. Hope you have a wonderful day.
The Following 4 Users Say Thank You to fixrite For This Useful Post:
chrisBC (06-11-2012), PaliBob (06-10-2012), Willie T (06-09-2012)
Old 06-09-2012, 01:20 PM   #14
Tom Struble's Avatar
Rewards Points: 2,002
hinges and pins have been adjusted this way for centuries,they are for the most part not precision items..some are but most are just stamped out by the millions
Tom Struble is offline   Reply With Quote
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
Old 06-09-2012, 02:00 PM   #15
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
I vote for the door stop only because this is the coolest doorstop I have ever seen.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Andersen door will not stay open Judy Nichols Building & Construction 5 09-30-2010 12:23 PM
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 02:17 PM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
