| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Pinning with a Nail Gun
by Expert Village
This is Rob McManhon for Expert Village. One method that is good to know with a framing nailer is pinning. This is something that you would use if you were building a header for example. Now a header generally for 2x4 wall would be whatever the... Read More »
How to Buy the Right Stud Finder for You
by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be talking about tips for buying a stud finder. I have two different types of stud finder tools and each one has its own pros and cons. On our first tool our stud finder gives us the... Read More »
How to Add Closet Door Hooks
by Expert Village
Ok, so if you have a small closet like I said before, then you want to get hooks. Now this is a designer piece you can get any kind of hook, you can get little symbol hooks or you can get a long array of hooks like I got right here. And what you would do... Read More »
Using a Scissor Jack to Change Motorcycle Tires
by Expert Village
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
General Uses for a Reciprocating Saw
by Expert Village
Rod McMahon for Expert Village generally uses for a sawzall is demolition or you could use it for cutting floors, you could get pretty precise once you have gotten use to it. Develop a little skill with it. As rough as it looks you could actually do some... Read More »
