How Do I Join These? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 04:41 PM   #1
how do I join these?
Due to a mismeasurement I am now having to use a 3" wood spacer between two new bathroom cabinets I am installing.
I've never installed cabinets before. I am wondering what the best and easiest way to attach these together are.
I do not have access to a drill press or anything crazy to make angled pilot holes just my standard cordless drill so I'm assuming that's what I should do.
Any advice would be greatly appreciated.
agentphish is offline   Reply With Quote
Old 04-06-2012, 06:14 PM   #2
DIY staff
Rewards Points: 7,174
Remove the door and drawer (if it has one)
You are going to screw that filler to the face frame of the cabinet---
Drill 3 holes into through the face frame --from the outer edge whare the filler will sit--into the inside of the cabinet---Make the hole large enough that a scre will pass without binding in the hole--
Add a counter sink to the inside of the cabiner so the screw head is flush ith the surface--
Clamp the filler in place---screw the two together--
Avoid black drywall screws---they are brittle and the head might snap off--use the gold colored screws.
An 1/8" pilot hole might be needed into the filler if the wood is really hard.---Mike---
kj6887 (04-06-2012)
Old 04-06-2012, 06:35 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
mikes right. its a standard practice for cabinet makers
woodworkbykirk is offline   Reply With Quote
Old 04-06-2012, 07:43 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Efface thine cabinets from memory, and get Thee to a podiatrist...
(Sorry, just couldn't resist making a comment on those bunions being in the pic.)
- Build Well -
Old 04-06-2012, 08:56 PM   #5
Ironlight's Avatar
What mike said.
And just to reinforce somethings...clamps are pretty mandatory in this case, to get the right placement and a good result. And definitely drill out the holes through the filler piece wider than the screws that are going through it or you won't get it tight to the cabinet before you start to split it.
Ironlight is offline   Reply With Quote
Old 04-06-2012, 11:49 PM   #6
Rewards Points: 512
nice work boots. lol
princelake is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
Angle to join in to main drain Mike Mike Plumbing 16 02-13-2011 12:03 PM
Can i join 3 phases together????? Motherhubbard Electrical 10 04-28-2009 10:50 PM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 03:07 PM
Need to Join some walls together. Need advice on a couple of things *Pics* J187 Building & Construction 4 05-20-2006 04:45 PM
