How Do I Join My Mitered Countertop - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 04:00 PM   #1
Rewards Points: 55
How do I join my mitered countertop
I ripped up some big old butcher black platforms to create countertops. I have one mitered joint. How do I fasten this thing?
I know how to fasten the particle-board counters with the miter-bolts, but how are those voids cut in the bottom of the counter?
I also know that I will need to dry-fit the the pieces together, perfectly lined up where I want it before I apply the fasteners. My question is what products are available to drill, glue, and fasten these things? I prefer something which will mechanically tighten rather than an option which requires clamps.
The closest I can come to an off the shelf product is Kreg, but if I go that route I will prabably just go the screw-it-together-with-long-screws route.
jkeuning is offline   Reply With Quote
Old 11-14-2011, 04:55 PM   #2
DIY staff
Rewards Points: 7,174
Do you own a router? That's the tool you need---a straight cutting bit will do the job of routing the slots needed for the counter top toggles----
I'd also suggest that you buy a 1/8"or 1/4" slot cutter and rip slots into both sides of the miter and add a spline.
A spline is a thin strip of wood that goes into the slot and helps align the two sides and adds strength to the glue joint.
Old 11-14-2011, 05:54 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
You can get the hardware for these at the big box stores. They are usually located where the Formica counters are. Another option is, if you don't have a router, to use a rail bolt that is used to attach handrails parts with. If your counter top is less than 1-1/4 thick these could be a little tricky to use but it can be done, and all you need it a drill.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
oh'mike (11-14-2011)
Old 11-14-2011, 07:30 PM   #4
DIY staff
That would be simpler than my suggestion----
Old 11-14-2011, 10:49 PM   #5
Cabinet maker
Augie Dog's Avatar
In a pinch, you could use draw bolts and bore the pattern with a drill and a little chisel work. Not as pretty as a router with a pattern cutting bit but it is very easy to do. And the joint is much more forgiving than the tighter tolerances of a handrail bolt.
Augie Dog is offline   Reply With Quote
Old 11-16-2011, 10:21 AM   #6
Rewards Points: 55
Well, that was an adventure.
I started with biscuits along the length of the joint. Dry fit it, and things seemed ok. My plan was to use pocket screws to draw the joint tight. I applied the glue and fit the pieces together. I sunk two screws in the short end and that drew the edge together. Then the world fell apart. The screws would not draw the rest of the joint. There were a number of problems, which I will not go into here. OK, I will. 1. The screws were not grabbing the end grain with enough traction. 2. Maybe the were not long enough, but I had an inch. 3. Maybe they were not large enough, they were number 8s. 4. I think I had too many biscuits in there and while they were lined up well, I think the glue and everything just made it impossible. 5. I did not have access to the sorts of huge clamps necessary to pull it all together.
So I ripped it all apart and cleaned up the glue, pulled the biscuits out as I was able.
Then got in the car.
Store number one had the miter bolts but did not have a pattern router bit.
Store number two had the pattern router bit.
Go home, make a pattern, route the opening for the miter bolt. OK, this is going to work. Problem was that the bit sucked and I knew that it was not going to survive all this oak.
Out comes the skill saw. I ripped a slice along the length of the miter on each board. Then a ripped slices perpendicular across the miter where my bolts would go. On one side I free-hand routed a slot large enough for the rectangular washer. On the other side I routed an area big enough for my wrench to fit.
Glue. Bolts. Disco.
It is drying right now. The bottom side looks like a bomb went off but the joint is tight and will hopefully set up fine.
If you look closely and the scars and dried glue, you can make out a word:
A M A T E U R
The Following User Says Thank You to jkeuning For This Useful Post:
Augie Dog (11-16-2011)
Old 11-16-2011, 10:51 AM   #7
Rewards Points: 56
A M A T E U R
Now, whenever you think of this experience, insert "proud" in front of that; "P R O U D A M A T E U R". Even the pro's make mistakes, but the good ones know where they are tolerable, and how to make them "disappear". Thank you for sharing, and keep up the good work!
Old 11-17-2011, 12:08 PM   #8
Agreed, you had the guts to try it! Good for you
mrgins is offline   Reply With Quote
Laminate countertop mitered joint question lemmy999 General DIY Discussions 5 10-18-2011 05:54 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 03:07 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 05:56 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 08:05 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 02:08 PM
